Door adjustment
GMCChevy
The bolts that hold the hinge to the body, there should be some play in the holes to move it.
GMT800 2005 Tahoe Z71
Navy Supporting Member
Hi All
I recently just put a used door on my front passenger and I need to adjust it forward towards the fender. Is there a way to do so?
Thank you
When you put the door on, how did you exactly do that? Was the door/hinge a bolt on type? Just mounted at the hinge pins?
I
Irish919
Massachusetts
As long as the pins are not wearing/rubbing thru, that gap is caused by the fender, the hinges themselves that are likely bent but more likely is where the hinges attach at the door and door jam, they are pulling away.
schafer98
