Installed Brembo big brakes on all 4 corners of my '19 Escalade!
NYBRD
Got Rears done today finally..... lol
J
jyi786
Wanted to provide some updates and observations.
1. The big 6 piston calipers are EXTREMELY sensitive to not being centered. You can eyeball it, sure. But if it's off by even .5mm (which is actually a lot), it will cause major issues.
I was having major issues with grinding on full lock turns, and what I felt like were the pads dragging. As a matter of fact, I know they were dragging; Acceleration was sluggish, coasting wasn't what it really used to be as it was with stock. I put up with it and dealt with it because I thought I couldn't find the right washers. The ones I was using were cheap Chinese trash from Amazon, and they were 2.5mm. Or were supposed to be. I ultimately don't think they could stand up to the torque required when tightening down the mounting bolts for the front calipers, so it got even smaller when I tightened the caliper bolts. The last time I was dealing with switching pads, the grinding became so severe I thought I busted the hub bearing or something else. Nope, it was the pads dragging.
I could tell when eyeballing it that I needed 3mm. Lo and behold, I found them! I can't find any other place that sells these. Sure, you can double up other washers, but like I said before, the quality will be questionable at best. Here is what I ended up installing:
ARP Racing 200-8535 ARP 2008535 10-Pack Of Special Purpose Washers, 9/16" Inside Diameter, 1" Outside Diameter, .120" Thick​
.120" is 3mm. I just installed them last night. Even though the caliper is still ever so slightly off center now, they made a massive improvement. No more rubbing/grinding on turns. Coasting is back to stock feel. Acceleration is way better than before. I highly recommend this to those who think they are having rubbing/grinding issues up front.
2. Ceramics like Powerstops are great, because they are quiet, but I was still dealing with the random squeal when cold. I really hated it. Semi-metallic pads fixed that. There is a tradeoff because you will have to deal with cold creep groan, which is kinda normal with semi-metallics, but once you bed them in properly, they will be drastically minimized. I can accept that over squeal any day. To follow that up:
3. Good quality semi-metallic pads make a huge difference in braking feel. They grab way better and give you higher stopping performance than ceramics, and if you thought you stopped better with these big brakes, the semi-metallic pads push it over the edge. I'm telling you that you have to feel it to believe it. I tried 4 completely difference pads for the 6 piston brakes up front and about 7 different pads in the rear. I can unequivocally tell you that semi-metallic is what you should be running if you want the best performance and minimum noise. I used these pads:
Front: MEVOTECH TXBPP2407
Rear: Hawk Performance HB727B.592 HPS 5.0 Street Brake Pads
Of course, I wanted to match the front and rear pads with the same manufacturer and product line. I was not able to do that. I cannot find quality (let me reiterate that word QUALITY) pads that are from the same manufacturer and product line that match. The closest I had are the Powerstops (Z37 up front and Z26 in the rear). I tried to use the best quality semi-metallics I could find. I tried DFC, they are complete garbage. I used Powerstop, and they are ok, but they have terrible bite when cold. I finally settled on Mevotech because I never used it before and they promised good performance, so why not take a shot.
The performance of the Mevotechs are pretty damn good when paired with the Hawks! That's the combo I'm running now and will try for a week and report back.
Hope this helps anyone who might be having some difficulties with the big brakes. They are finicky and need to be dialed in for the best performance.
MrMonte
Thanks, getting close hopefully to installing these on mine. Have everything except the washers which I just ordered.
NYBRD
22x9 24offset , fronts did not clear the 6piston brembo FML , need atleast .75 inch spacer and extended wheel studs now F..M..L lol had to put my original caliper back on
MrMonte
From what I read my 2018 Yukon Denali rims have a +31mm offset. Was hoping those rims would clear. Not so confident now
J
jyi786
Are your rims GM OEM or are they replica? Do you have the GM part number if original? 24 offset really should have fit, although I do understand that it's really up to the spoke design. Heck, if you look at my rims, you could swear they will not fit, but they do, and still have tons of clearance.
NYBRD
They are oem. Really a bummer now I have to find the correct extended wheel studs,remove the wheel hubs , find a custom.75 hubcentric spacer . Pain in my @$$ lol and then hope I have the right measurements that my oem lug nuts will fit just right
MrTris
I like those wheels - looking at getting a set that I'm eyeballing on Marketplace, locally.
So, the brakes fit under the rears, but not the fronts? At 3/4" spacer, plus longer wheel studs and the rest, are you anticipating Mеxipoke, or just a slightly more aggressive stance?
NYBRD
Rear was very simple install with those wheels. The fronts on the other hand with a .75 spacer should have the tire flush with fender il find out as soon as I have them on il report back. I have seen these oem wheels sold as replicas for a pretty good price brand new. Could always do replicas if its easier on the pockets.
NYBRD
Ended up not needing the extended wheel studs, the ET extra threaded lug nuts were more then enough
NYBRD
Forgot to mention I ended up going with 15mm hubcentric spacer which I think is .59 of an inch which was enough to clear the caliper
6x139.7 or 6x5 same thing
78.1 hub measurement
15mm thick.
& ET extra threaded lug nuts
Hope that helps anyone if they need it just in case
sabastian458
My 2018 RST already had the bigger Brembo on the front. I had to replace the rotors and pads last year and did pretty much the same thing for the fronts. I used 2023 Escalade V front rotor part numbers and crossed them to aftermarket rotors, bought the coated ones, then after 2-3 tries was able to get pads to fit. I did also replace the backing plates with the Escalade V ones that properly cover the larger rotor, I hated that GM did not provide replacements with the Brembo kit.
This year I did the rears with the CTSV brackets, but I bought the caliper kit from GM as any used calipers I found were running $275-300 each. The GM Camaro kit came with both calipers, bolts and seals for $500.
992dr
Eastern N.C.
If anyone is interested, I have a complete rear set up less pads in the F/S section.
atr87
@jyi786 thank you very much for the detailed parts list and sharing your experience here! I plan to do the PPV upgrade in front and perhaps the rear BBK as well - on my 2018 escalade 4wd using your guide.
Question - for brake lines, any idea which SS versions and banjo bolts would work well with the front/rear calipers you've outlined?
J
jyi786
Happy to help!
Two things, I can help save you money. I uninstalled my rear brake kit; you can have it for a huge discount. Comes with calipers (including banjo bolts), brake pads (your choice of 4 different pad sets or all of them if you want), and the CTS-V bracket. You can PM me about it.
Now about the rear SS lines, I am actually looking for them myself, but have been unable to find any thus far. I think BFGoodrich was the only option.
MarvinVR
Tigard Orygun
Sorry if I missed this but what was the total cost of the project? Ive just started to study this. What about the GM stock police brakes? Are they not bigger than normal AND cheaper than Brembo? hats the smallest diameter wheels that work? I cant afford to replace the stock wheels and prefer smaller wheels and more sidewall anyway Wait--just followed one link. $421 for ONE caliper? Oh hell no. I'll just take extra time when braking LOL
NYBRD
Happy to help!
Took off your rear brembos ? How come?
1948Buickroadie
