No start condition
fgxmfmq
I am having a no start condition and wanted to check the fuel pump relay and fuse. Having a hard time trying to determine which one. The schematic doesn’t actually say fuel pump etc
2021 Yukon Denali 6.2 gas
blanchard7684
Senior Member
I believe the fuel pump control module contains a relay and a fuse.
The fuel pump control module is on driver side frame rail near the rear door.
Check the post below for a recall notice to see if yours is part of that.
F
fgxmfmq
So there is not a seperate fuel pump relay or fuse?
jfoj
Lock vehicle and allow it to sit 10-20 minutes, walk up the drivers side rear door and then use the keyfob to unlock the vehicle. You should hear the fuel pump prime, it is pretty loud, lasts about 2 seconds. If not, probably the fuel pump control module.
The fuel pump control module is very easy to replace from under the drivers side rear door. It is in a bracket mounted to the frame rail. But I think you need E Torx bit to actually remove the module from the bracket.
While the module may be recalled on your vehicle, if you could get a module from the dealer, you can get the car running immediately. 10 minutes, 1 connector and the most difficult part is figuring out how to remove the red locking part on the connector! No programming necessary. I think the modules were around $65 as I recall. If you could get a module quickly, I would replace it then if the vehicle is recalled, take it in and have the dealer do the recall and give you your working module for a spare. For me it is not worth $100 for the vehicle to be out of service for a few days, need to be towed and have someone take me to a dealer to pick up the vehicle.
I have 2 spares under the rear floor storage area in my truck. Why 2, 1 for me and 1 for the fellow GM owner stranded that will hopefully Venmo or Paypal me the money for the spare module to get them back on the road.
Would someone help @fgxmfmq with how to disconnect this connector?
jfoj
Usually you just pull that red locking pin out of the connector and then the connector should be able to be released
fondupot
South Carolina
@Fless The locking tab needs to be pulled down, then the gray handle needs to be pulled down like a lever and it rides on a groove and pops out the connector.
fondupot
South Carolina
@fgxmfmq The locking tab needs to be pulled down, then the gray handle needs to be pulled down like a lever and it rides on a groove and pops out the connector.
Bwaldron
