Passkey reset issues
giroux68
After doing some work on my 2010 Denali, the pass key decided to not work. Security light is steady. I've done the 3x 10 minutes. And nothing. Disconnected the battery over night...nothing. Different keys..nothings. any other idea? Thanks.
DOD delete..etc. All was well prior
Marky Dissod
Disconnected the battery over night ... nothing. Different keys ... nothings. any other idea? Thanks.
DOD delete ... etc. All was well prior.
Did you physically delete Engine Half@$$? Or did you just have it disabled?
Either way, what steps were taken during the disablement?
mikez71
VATS can be turned off in tune. Possible it was turned off, but you didn't write the new OS?
BCM turns on the light..
Passkey3+ module (rcdlr?) reads the key and communicates with the BCM.
Broken antenna ring in the ignition could also cause this.
A good scanner might narrow down where the problem is.
when you did the 3X10 on the last 10 did you then try to start or turn it back to off again?
G
giroux68
I had the DOD done with a Texas speed cam and a tune at a local shop over a year ago. I had some evap leak issues and a fuel gauge problem last week. Dropped the tank and found a vent line unhooked and replaced the fuel pump. Evap and fuel quantity fixed. I got rich bank 1 and 2. Fuel alcohol level is at 78%. I disconnected the battery to reset the alcohol %. Didn't work. But 2 or 3 days later it wouldn't start. And the pass key security light on dash is on. Keys in the ignition warning ding with door open not working. I tried the 1 hour reset I found on YouTube too. I'll try the 10 minute cycle again and go for 4x or 5x. I have a blue driver OBD2 reader.
G
giroux68
Ran the blue driver OBD2.
G
giroux68
I did try the BCM fuse pull tech. I found on YouTube. So these might be from swapping fuses.
Buford bubba
