West 1
- Joined
- Jan 20, 2023
- Posts
- 699
- Reaction score
- 1,503
2007 with 6L80 and 6.2L code U0073-00 check engine and stabiltrak light
Hoping to find a quick solution to a ongoing problem. My 2007 Escalade has been a challenge this year. It dropped a valve seat, broke a piston and ruined a cylinder head. Got all that fixed. It was running amazingly well. I had to tow with this car, 6,000 pound trailer, it did the job very well but coming off a street light with this load when it went to shift from 2nd to 3rd and it went into neutral, check engine light came on and I coasted to a stop. I had my scan tool with me so I checked the code. U0073-00. Says lost communication with can bus A. I cleared it and drove away again. Same thing 1/4 mile later. I limped it home and called a tranny guy local and he said very common issue the drum inside the tranny has cracked and is expanding when it tries to pull the load which dumps all my line pressure. Sounded right to me based on the failure so a New Tranny installed, I did the install, he rebuilt the 6L80 with all brand new parts from GM or Transtar. Drum was new GM, he said it is improved so this won't happen any longer. The Module was not replaced but it was refreshed with the (Sonax) kit that has all new seals for the solenoids. After install it shifts great. After reset of the TCM you are supposed to drive easy and let it slowly reprogram. Did this with zero issues and it is shifting really well. After this initial break in, I try to accelerate harder, maybe 30% throttle, not hot rodding. It did the exact same thing it did before the new tranny install. Damn, out $2500 and a ton of labor installing for no change? I will also share the problem originated with towing the heavy trailer, coming off a light under lots of torque. I imagine the engine was twisting more than normal on the engine mounts, maybe pulling on some wires or grounds? The failure only happens when under load accelerating. Not race car stuff, just a little harder than normal stop and go driving. Never triggers going downhill. Always triggers on the 2-3 shift if pulling any harder than gentle.
The code clearly states loss of communication. Tranny guy now says it is the module. Another $1,000. Have not done that yet. I have a good scan tool with 2 way communication. I am trying to learn how best to test the Can Bus system. I am not a good electronics guy but trying to learn.
Side Note: Since both heads, the oil pan and starter and all been removed for the recent engine repairs I am wondering if a ground or other wire may have been pinched or left loose causing these CAN system error codes?
I sure wish I had walked this route before installing a new tranny. I think my old tranny was fine, I even studied the repalced tranny parts and they all looked good, even the old drum looked perfect, I think the Can Bus is the real issue, might be my module but could be many other issues.
So far I have tested the Can Bus wires for continuity and did a 5 amp load test on them. There are 4 Can Bus wires to the Transmission TCM. Two for high speed data and two for low speed data. One of the high speed wires shows 2.8V constant, I do not have a osciliscope to test with. The low speed Can one wire shows a 2.2V constant. Both of the other two Can wires are dead, no voltage, I don't know if this is normal or not. The ground at the TCM and the 12V+ are good, the 12V Acc Power is also good with the key on. Not much else I can share at this point.
I have seen others on this forum with the exact and similar issues. Hoping someone can share a common solution. Thanks
West
West
