Silverado 4 Piston Caliper upgrade done
GranPrix
I noticed there's not many or any of these caliper swaps for the 15'-20' models so I'll post up all the info from my upgrade.
OEM Rotor specs:
Diam: 12.99”
Thick: 1.181” / 30mm
Silverado specs:
Diam: 13.58”
Thick: 0.790” / 20.06mm
Calipers:
GM# 13545382 DRIVER
GM# 13545383 PASS
8 1/8” thick washers/spacer so the caliper can center with the rotor.
Banjo bolt:
GM# 11569589 30/ftlbs
Caliper bolts:
GM# 15016308
OEM 18" Wheels
1/4" spacers for the Calipers to clear the wheels
Rotors:
RST Dana
OH
So far I’ve driven over 500 miles now and the difference is night and day. Very pleased with no complaints
When you put them in the oven, did you remove the pistons?
petethepug
Michael
SoCal
Nicely done. That upgrade brings it up to what GM should have had as a factory option for a tow / performance package a long time ago. It’s such a great platform most owners drive these trucks like a light import passenger vehicle.
If you zip these trucks with short stops and in the same spirited fashion you would a a Honda CRV, the brakes are gonna remind you that you’re moving 3T around with a pulsing in the pedal from warping or pad build up.
TxVet33
Abilene, TX
Outstanding post and how to. So my '19 Yukon XL SLT has 20" wheels/tires, so probably no grinding is needed?
mach1z
Here is a photo with caliper on my 2017 TAHOE with Z71 Wheels-18in. One could get away with grinding a chamfer on to the inside edge of the caliper before installation. However, I did the grinding after it was mounted so I had to touch the center rib to get that angle.
TxVet33
Abilene, TX
OEM Rotor specs:
Diam: 12.99”
Silverado specs:
Diam: 13.58”
Calipers:
GM# 13545382 DRIVER
GM# 13545383 PASS
Banjo bolt:
Caliper bolts:
GM# 15016308
OEM 18" Wheels
Rotors:
That is a labor of LOVE! Looks great.
a1parrothead
