2025 Tahoe Grab Handle
contenderv07
I've got a 2025 Tahoe and want to install a grab handle so I can then install the grab handle mount for an Edge CTS3 monitor (diesel model). I assume if I ordered the Silverado one it would fit?? Also I'm looking for any vids on the uninstall. I guess its the same as the earlier models? Thanks for any help
2024 White Tahoe
I’ll follow this thread.
I can’t believe GM did not put a grab handle on the LF A-pillar of the Tahoe. I hate the ceiling mounted grab handle, especially for getting out of the vehicle.
LegalBrief
Senior Member
Get the one for the Sierra, screws and caps.. ou may need the A pillar trim piece as well. gmpartsdirect.com
Stbentoak
Are the thread mount holes on the frame of these vehicles like the PU trucks? Won't do any good to buy parts if there is no place to attach them. Has anyone confirmed this?
C
contenderv07
C
contenderv07
sorry this took so long... I talked to the parts guy and he said that he wasn't sure (big help). I'm going to see if I can find someone that can 3D print something or just go the suction cup route. I just sent sent an email to GMParts and I'll report back if I hear anything
StephenPT
St. Helens, OR
There's no nut-serts in the sheetmetal of the A-Pillar on the SUVs for the LH grab handle. I've had it off before to check. I ended up modeling a 52mm gauge pod and screwed it in from the backside of the pillar to mount my Bank I-Dash.
C
contenderv07
dang ok thanks... and got this back from GMParts....
Hello,
Thank you for visiting www.gmparts.com.
In regards to your inquiry, part number 86526027 does show in our catalog that it is used on some 2025 Chevrolet Tahoe builds. Because the part did not come installed on the vehicle, and would not be listed as part of the build for the VIN, we are unable to confirm that the part will work for your specific vehicle. There may be some technical reason that the part wasn't included in your vehicle's build.
If you have any other questions, please respond to this email or feel free to contact our experts at the GM Parts Support Center by chatting with us at www.gmparts.com or by dialing 1-800-223-3526. Your GMPSC Case number is 9-15697686119.
Thank you and stay safe!
C
contenderv07
alright so I got the idash and ordered (reluctantly) a mount from ETSY. If it's a little shiny I may sand and paint it, but we'll see what happens
Javelina
Pleasanton, CA
Can you elaborate on your install? I wish to add a Banks in my 2025 Yukon Denali.
scottd
