- Joined
- May 9, 2018
- Posts
- 7,197
- Reaction score
- 14,009
Ok, I assume there is a thread somewhere…. Turning ignition back on, the time is not accurate. What’s the fix?
( factory 6 disk changer style )
Turning on ignition, it displays 12:00 am. But the annoying glitch happens sometimes…..Define "not accurate." I assume that the time is correct before the issue, but to what does it reset? How far off is it?
OK… thanks… I’ll check my battery….. It’s an AGM. Less than a year old…..Battery connection or weak cell in battery would be my guess.
1st time… this morning my starter was hesitant to start…….Battery connection or weak cell in battery would be my guess.
Clock seems good now….. I will figure a way to secure the battery connections better ( side-mounted )1st time… this morning my starter was hesitant to start…….
YOU are correct….. I tightened the battery connections…. They were not REAL tight….
I think it is solved… I will find out later this morning…..
I have my 8mm zip-tied to my battery handle.I keep an 8mm box wrench in the fuse box that is next to the battery. That has been there for years. I've had good luck with AGM's. I had 3 Optima Red tops - in the 1500 XL - 2004 - 2011, 2011 - 2020, 2020 - 2023 ( when he left me due to frame rot ). in both trucks ( 2001 and 2002 ), I get a reset of the clock a couple of times a year. I stopped looking for the cause.
