How to get this off????
Sepiroth
I am here
Kouts, In
Are you using a wrench. Man I hope not, if you are youre in for a world of hurt. Use a breaker bar and deep wall 7/8 socket.
---------- Post added at 01:46 PM ---------- Previous post was at 01:45 PM ----------
This was gonna be my next response.
Sure it was, lol.
chistoso
Arizona
I was minus the vidoe part. I noticed in the pic he had the nut in with the flange towrds the axle. should've run the flat side of the nut. It shouldn't take soo much pressure to pull these babies thru.
BOSS
BOSS
The People's A D M I N
Dallas
Thats how Ive always done em. But, I NEVER used a wrench to do so.
I'm about to get back to it in about 30mins..think I got it now with the flat side of the nut instead of a washer
B
Sepiroth
I am here
Kouts, In
I hope so mang! I'm all frustrated over here and I can imagine your frustration level.
HMFDZ28
Hunt Sta, NY
you need washers, greese and the lug nut... granted I used to do it with my impact gun but you should be able to do it by hand also. you just need to reduce friction
BOSS
BOSS
Dallas
oops wrong video...will repost
BOSS
BOSS
Dallas
Forgot to turn the camera off..it ends at almost 4mins unless you wanna see what a clean engine looks like :D
[yt]YXlp1ZnP4Zs[/yt]
BILLY MAYS HERE!!! Hope this helps someone!
BOSS
BOSS
BOSS
Dallas
Good video. Finally you got it done. I wonder why the whole thing didnt go in?
I think it would but damn if I'm gunna put more force on em...I thinks that's what caused me to strip that one out...dunno?
B
Sepiroth
I am here
Kouts, In
Yea what caused the other one to strip out was the use of the wrench and opposing forces. I mean you're trying to draw the stud in while at the same time trying to use the knurls as a hold down while twisting the lug nut on. Two forces and somethings gonna give.
IMHO, an impact and some air pressure would have made the job go way way easier. But, in a pinch, what are you gonna do.
It would be wise to not drive too far when you reinstall your wheels. Install your wheels then after about a days driving, but no more than 50 miles, check the torque of the lug nuts. Pay special attention to the studs you replaced.
BOSS
BOSS
Dallas
What torque? 130-140??
Remember I have some "light weight" 24s :D
BOSS
BOSS
Dallas
Figured it out BTW. You MUST use washers that will fit the entire length of the stud. The stud gets thicker at the end after the threads (see video) and the flat side of the nut almost can pull the stud through till that thick end starts poking through. What happens is the nut pushes up against the thick part of the stud coming through, and the thick part obviously has no threads but the nut gets stuck on the thick part before you thread out.
NOW I AM A STUD GURU LOL!!! :party33:
BOSS
---------- Post added at 04:56 PM ---------- Previous post was at 04:55 PM ----------
BOSS
That is why I stripped one out btw...
B
vsaravia
