Anyone know how to program the remotes?
ThwopKing
Bunker Hill, WV
Does it have to be done with a GM scantool or can i program it with a a few/several cycles of the key like in fords?
Z-56 Hoe
What do I do????
Houston
this is My secound Cheby I have always had Fords, and I do not belive so I had a handheld tunner and now I have a HP tune. what are You trying to do exectly?
Redhoe01
The BDG
Forney, TX
Ask and ye shall receive.
1. Close all vehicle doors.
2. Insert the key into the ignition.
3. Hold down the power UNLOCK button on the driver’s door panel-continue to hold
down until instructed to release in step 9.
4. Perform steps 5 through 8 in fairly rapid succession.
5. Turn the ignition switch to the ON position (as far as you can go without starting the
engine).
6. Turn the ignition switch to the OFF position.
7. Turn the ignition switch to the ON position.
8. Turn the ignition switch to the OFF position.
9. Release the power unlock button on the door panel. The vehicle will lock and unlock
the doors automatically.
10. Hold down the LOCK and UNLOCK buttons on the transmitter simultaneously until
the door locks and unlocks.
This step may take up to 30 seconds.
11. Repeat step 10 NOW for each additional transmitter (including any existing
transmitters).
12. Turn the ignition switch to the ON position in order to exit the transmitter programming
mode.
ThwopKing
ThwopKing
Bunker Hill, WV
Thanks RedHoe..i found that online but i couldnt find what years/models it was for..but thanks again and ill try it here in a lil bit and let ya know how it works.
Thumper8302
OKC, OK
this didnt work for me but i could have either a bad fob or something wrong with my module itself.......
Tahoewhat
Ballin' on a Budget
TX
To add to the instructions, you have to make sure that the remote numbers on the back of the remote are the correct numbers. If you have the original one w/ the car, then just double check the numbers are same. Cant think of what they say right now, think like model number, or fic.. something. If its not correct, it wont work w/ your application. I know b/c i had to do it to my tahoe when i got it, and had the wrong numbers, got the right ones, did those instructions and worked like a charm. Also, just to make sure, make sure you have good battery in the remote.
chip
Cincinnati
Awesome advice guys! This should definitely be a sticky!
Thumper8302
OKC, OK
i have the correct fob and as soon as i had bought the vehicle i threw a new battery in the fob.... so who knows:emotions122:... i will be goin to a viper anyway
Tahoewhat
Ballin' on a Budget
TX
Thumber, dont know why yours isnt working. Like you stated earlier, you might have a bad module or something. But if you are going to a viper, then no big deal. You wont need it. I dont use mine anymore, only the viper remote..
Thumper8302
OKC, OK
need to go somewhere so i can test the fob.. i know autozone used to have a lil dilly thingy by the register that u could aim ur fob at to see if the batt was good..... i heard somewhere where somebody stated somethin could mess up in th bcm but i dunno
Redhoe01
The BDG
Forney, TX
my original fob stopped working as the metal piece holding the battery had a crack in one of the soder points. I tried to resoder but it didnt work. Order a new one with matching numbers, worked awesome. Got it off ebay for $17
Rick
Langley, B.C.
did this to my truck while on a road trip to the inlaws. must of looked over this site for at least an hour with no resolve. then googled it. first web page had the instructions. worked like a charm for me. still dont know why both my fobs stopped working. as stated above this should def be a sticky!
Thumper8302
OKC, OK
ha ha ha lemme guess.. it was the tab on the inner most area that held the batt.... i just pryed my fob and low and behold ,,,,, broken joint..... imma try and re-solder this while im at work later on today.... but atleast i know whats up with this hunk of plastic on my desk.. thanks man for savin me some gas goin to the parts store lol:Handshake:
Redhoe01
The BDG
Forney, TX
Exactly, same one. I was told you need a special soder gun (lower heat) for electrical boards but you may already know that. Trying to find the link to the fob I bought on ebay for $17. Great deal and well worth it.
ThwopKing
ThwopKing
Bunker Hill, WV
The FIC numbers of the remotes have to match. When I got mine form this ebay seller they listed a set of FIC ID numbers that would work. But i just tried the process and it didnt work. Even with me holding the unlock button down the locks cycle everytime i turn the key to off position....anyone have this problem? Also im still trying to find out if the KEY is a transponder key or not.
Redhoe01
The BDG
Forney, TX
I found that the numbers had to match. I could get the locks to cycle with a non numbers matching fob but not when I I hit the last two steps.
ThwopKing
ThwopKing
Bunker Hill, WV
My numbers match as well but the process just didnt work..i guess off to the dealer i go...
Escalade2007
