Solved - 1993 Blazer/Tahoe cranks but won't start
BulletProof
So I don't drive my truck much... maybe 3000 miles a year. Anyway, I keep a battery tender on it in the winter and start it up once a month and let it run until it gets warm. So I went out to start it the other day and saw that the battery tender had become unplugged, and the battery was dead.
I grabbed my battery booster (Noco BoostX) and hooked it up, and went to start the truck. Battery was too dead and so I had to use the override mode on the Noco. When the Noco engaged, I heard a small "pop" sound from somewhere in the engine bay. I cranked the engine... good long steady crank, but no joy... no spark? no fuel?. Very weird, this truck always runs, and now I am wondering if the Noco might have burnt something out.
Any suggestions where I might look first?
PS: Not a mechanic, but between YouTube and patience, I tend to muddle through.
exp500
Follow the Pop! First check is battery cables clean and tight. Next check fuses. Remove air cleaner and check you are getting fuel. Attach spark ckecker to coil wire. Justa few quick tests that may help indicate which direction to go.
BulletProof
BulletProof
Appreciate it!
Eman85
No spark? No fuel? No check for spark and fuel? Clean your battery cables, charge and or replace battery if still no start check for spark with a spark tester and fuel pressure.
BulletProof
BulletProof
OK, update.... Sorry for the late reply, was trying to diagnose the issue but the issue became so intermittent and inconsistent that diagnoses became impossible until it dawned on me... the computer!!! Replaced the computer - problem solved. Jumping the truck must have blown something in the ECM/ECU. Replacing it solved the issue. Truck is back on the road. Thank you to all who spent their time giving advice.
OBSTheBest
Those dang intermittent problems are the absolute WORST. Dealt with one myself. Extremely frustrating and mind draining.
Glad you're back up and running, and the truck is back on the road where it belongs! :cool:
See if you have the dropdown three-dot at the top of the thread; click on it, select Edit thread, and have at it.
a1parrothead
