Intermittent Burning Odor In Engine Bay
EddieC
Having an odd intermittent burning odor from engine bay.
The odd thing is if I work the truck harder like on a long climb then the odor prominently shows itself.
Tranny temperature is normal for what it has been in the past and the odor is more forward than that.
I'm not seeing any engine oil leaks in the engine bay and as noted the odor is not consistently there like an oil leak would be expected to be.
Also engine is not using more oil than usual which is about a quart between changes (5000 miles or so).
Power steering fluid is very old and has a burned odor and the pump had some seepage below the shaft that cleaned up and was slow to return but the high pressure line is damp near the crimped end.
Main and AC Belts were changed a few months ago as well as idlers (more recently). I haven't gone back to check the idlers.
Any thoughts?
Big Mama
Virginia
Is it an oil burning smell, a burnt wire smell, an overheating smell, a brake pad smell? Any smoke? I’d try to hunt this down sooner than later. Check your battery and ground connections too.
You may notice it more going up a steep grade bc you’re going slower than normal. Do you see anything on your exhaust that may signal the location?
EddieC
EddieC
Not motor oil burn smell. It's hard to describe. Perhaps between electrical and something else. It's not from the alternator and I suspected the PS area as that was the general location until yesterday is was on the other side. PS fluid does smell burned.
Also definitely not a brake pad odor and no visible smoke.
The dash gages don't show temperature or oil pressure any different than normal for the vehicle. The DIC trans temperature also shows consistant historical values.
The dash voltmeter does vary from about 12 to 14 volts at various times but that was deemed not abnormal in another thread.
The HVAC fan has started making slight noises at times/certain speeds but the odor, although sometimes in the cabin but less strong, is more in the engine bay. I might guess that the HVAC air inlet is drawing it in.
did a motor mount blow it's goo out? generally whatever they use in the mounts leaves a noticeable stain below it when they crack and it leaks out, that could be what you are smelling
petethepug
Michael
SoCal
The bearing in the hvac fan can start to go and heat up from friction. That in turn causes the fan motor resistor to heat up which gives off the smell of electronic fajitas.
jvanwanz
I just had this issue with my '15 Yukon 5.3L. Valve cover gasket driver-side was leaking. Dribbled down to the exhaust manifold. Smoked enough where the HVAC sucked it into the cabin. Had the gasket replaced and no further issue since this past February.
bill1013
Air Force EMT/First Responder Firefighter
Waianae, Hawaii
The plastic heater hose, where it goes into the firewall, may have a small crack. The engine RPM goes up and the water/coolant pressure goes up. A small leak, over time, becomes a major break. Hope this helps.
petethepug
Michael
SoCal
Oh yea, had that happen before. That made quite a smelly smell. Just don’t keep driving it till all the coolants gone.
EddieC
EddieC
Thanks for the idea.
This morning I rechecked the drive belts and two tensioners I recently replaced. No odd pulley movement (on anything drive related) or belt abrasion issues there.
The PS pump face is damp under the shaft. An obvious need to replace that and a weepy high pressure hose but there is no noticeable wobble in the shaft by gripping the pulley.
Idling in the driveway the odor is not noticeable.
No oil or coolant leaks including at the firewall as someone else experienced. The driveway does not show any leaks under the truck either.
Sniffing toward the source I tried to disconnect the radiator cooling fan on the predominant odor side but didn't leave it unplugged because it causes the other fan to max out and I thought it might do t harm. Both fans do run when called on.
One a test ride the odor seemed less prominent but subsequent rides shows that doesn't seem to be it.
Next i removed and unplugged the suspect front hvac fan. That seems to have also reduced the odor but as above it doesn't seem to be it.
I hadn't thought the odor was electrical but perhaps it is.
Alternator gives no odor but it seems perhaps it is near or on the side of the battery and coolant overflow jug and the "fuse-fusible" thing mounted on the firewall next to those things.
Someone suggested checking grounds and indeed the battery negative ground to the block was a bit flaky. Cleaned that up and the continuity tests were then good, but the odor persists.
I'll look at the motor mounts as suggested because one is in that area too.
One added thing noticed on this morning's run is that the oil pressure at speed seems higher than normal. I don't ever recall seeing 60 psi before. Off throttle or cruising it's back to normal 40 psi but the high is odd on a nice warm Spring day. Perhaps a filter change is in order to see if it might have an issue.
EddieC
EddieC
It seems like I can usually smell the odor at the battery and between the battery and coolant jug.
Can a maintenance free battery emit an odor for some reason?
petethepug
Michael
SoCal
Yes, it’s possible. A good indicator for overcharging and bad grounds is heat. Start by feeling for hot wires in the harness around the suspected areas. Battery posts or it’s wires should not be hot.
Big Mama
Virginia
It could but it sounds more like a frayed wire or something touching the exhaust manifold on that side or possibly coolant leaking from the overflow. Check those hoses and clamps. You can get an inspection mirror or a fluoroscope from HB cheap.
LegalBrief
Senior Member
Totally different direction here.. have you looked for critter damage or droppings? My old truck had spot the critters loved, when it got hot the droppings would “roast” for lack of a better word. Pressure wash and sone steel wool was all it took for them to move out.
EddieC
EddieC
No critters.
EddieC
EddieC
Maybe I can refine to current observations.
Odor is most prominent under harder working situations like pushing or going up a hill.
Casual unstressful driving or idling in the driveway it's barely noticeable.
It is intermittent, varies with driving conditions. It is not constant like a leak would seem to produce.
It still seems near the battery/coolant bottle.
Coolant looks and smells ok.
Big Mama
Virginia
Unless it’s a fluid landing on your manifold or exhaust somewhere and burring up completely there should be some kind of evidence left behind. An inspection mirror or fluoroscope might help you find it. Harder acceleration means the exhaust is hotter so more smell. I wonder if your O2 sensor wires could be the culprit. Their’s one right where you’re noticing the smell.
EddieC
EddieC
Worth a look. I would assume that a burned sensor wire would throw a code though. Tomorrow is another day to get back at it.
It seems so focused near the battery I wonder if something in there failed or got damaged by the alternator.
Big Mama
Virginia
It could have but, like the O2 wires you’d probably know. It’ll be interesting what you see bc usually you can see stuff pretty well from the bottom side.
petethepug
Michael
SoCal
I usually discovered stuff like this was electrical.
* A heated / cooled seat harness baking.
* hvac fan resistor overheating
* hvac duct modulation servo going.
* battery or super fuse poor connections.
Grady_Wilson
Wyoming
Did you find the odor source?
Your oil pressure sounds high for a properly warmed up engine, I would look into that.
Maybe try adding a quarter quart of transmission fluid to your oil to help clean up any gunk hanging around that may be impeding an oil passage.
Conedaddy
