Rattle coming from seat belt area in driver side?
tahoe81
Noticed a rattle from where the seat belt comes out of the frame in the driver side. Anyone have an idea what it could be or what I could try to tighten to fix it? Pic of the general area attached.if I press a bit on the chrome hardware circled it seems to suppress the rattle
Big Mama
Virginia
Does it change if you raise or lower the seatbelt height adjuster? Are you wearing your seatbelt?
T
tahoe81
It doesn’t seem to change if it’s in a different position and yes I'm wearing the seatbelt.
probably have to pop that pillar cover open and take a look inside, sometimes all it takes is a small piece of felt or even a piece of tape to quiet up a rattle noise.
harbor freight sells plastic trim tools so you don't mare anything up, and there may be a screw holding it on, if there is sometimes they just have a plastic cap covering the access hole. haven't looked that hard at the t2 interiors yet
T
tahoe81
Thanks. It’s under warranty and I’ve got to go in this coming week for a software update and other things so I may just mention it to them. I just didn’t want it to be something where they had to take the entire door apart to do it and deal with all that
KMeloney
I feel like I hear something over my shoulder/head up in the area, but I wonder if it's actually coming from higher up and farther back in the truck, like from the rear driver's-side door's internal trim/weatherstripping or something. I only hear it over bumpy road surfaces, but... I hear it. lol
Big Mama
Virginia
Sometimes the lock mechanism rattles around. The only thing above there is the same seatbelt point the OP mentioned. Go to your rig and open the door and shake it. If no noise pull in the seat belt anchor. Anything above that is in the headliner.
T
tahoe81
I have this going on currently too which is a separate issue from the seatbelt one I posted about. I've heard a clicking type noise for a while that sounded like it was coming from behind me. After making my wife drive me around so I could determine where it's coming from, I discovered it's the second-row driver-side captain chair. Right inside the middle of the chair (where a person's shoulders would rest) there's a clicking noise. We discovered that it seemed to mostly stop if we folded down the headrest, so Chevy ordered me a replacement headrest which didn't fix my issue. Now (this coming Friday) they're replacing the entire seat frame and hardware to try to fix it. I've had my Tahoe in to the dealership maybe four times for this issue and have ridden with the lead technician a couple times and he hears the noise too but has no idea why it's happening. We're just throwing stuff at the wall hoping something sticks at this point, I think.
Big Mama
Virginia
Does the noise go away if the headrest is out? I’m wondering if one of the channels the headrest supports go in have come loose and are rattling around.
T
tahoe81
Good question and I'm not sure. To be honest, I'm not entirely sure what the mechanism is to remove the headrest, but I'll check it out and report back. I know there's a button the side but that button just seems to lay it down. I have no idea if the dealer has tested this theory or not, but I assume they've not. They seem to want to do a little as possible and just hope it goes away on its own lol
T
tahoe81
Sorry for multiple replies on two different topics but when you say "shake it" you're referring to the part pictured in the OP? FWIW, I feel like I can duplicate the sound by pressing on the chrome piece that's inside the part pictured. There's a chrome loop which the seatbelt goes through in that opening and it kind of flexes back and forth and side to side to allow the seatbelt range of motion. If I press it, I can make it click a bit which sounds like the same noise I hear when I'm driving. If when I'm driving, I press that chrome piece down and hold it, the clicking seems to stop
Big Mama
Virginia
You hit the nail on the head. My rig is older but it has a button at the base of the headrest supports that let you remove it entirely.
T
tahoe81
I'll check it out this evening. Thx!
JayceeP
Hey guys. I have the same issue. 2024 Yukon XL SLT with luxury/premium package (ie moonroof too) but 2nd row bench. 6,500 miles.
Any luck with this? Like @KMelony I would describe the sound the same. I’ve pressed around the shoulder/seatbelt area and the liner above my head. The rattle seems to chatter more over bumpier roads.
Even though I don’t have captains chairs in 2nd row could still be the headrest issue.
T
tahoe81
My noise is definitely coming from the seat belt mount where the belt goes into the frame of the vehicle. There's a metallic piece in there which I can press and hold and the noise will go away but I've not been able to see anything which can be tightened. Mine seems to not be as pronounced or as consistent as it was, but it's still there.
Big Mama
Virginia
Can you loosen the bolt and put a foam O-ring or a piece of padding between the two metal surfaces?
T
tahoe81
Possibly. I've not looked too closely to be fair, but it's not immediately obvious how I'd even access the bolt to loosen it. There's a plastic cover over it which doesn't look like it will pop off in any way to present the hardware under
Big Mama
Virginia
Get a set of plastic trim removal tools. At Hobo Freight they’re about $10, or Amazon. Go slowly starting at the end and do a little at a time.
varminpoolteam
