High pitch tone behind instrument cluster?
Roilux
Senior Member
Firefighter Supporting Member
Burbank, CA
It's happened twice yesterday, briefly, and I'm stumped as to what it could be. 2004 Tahoe LT, 5.3, 2WD. 170K
City driving, 35 to 40mph, climate control off, driver's window down, radio off. The first time it lasted for 15 to 20 seconds. On the second occurance the tone lasted for over a minute. That gave me enough time to adjust every climate control setting and fan speed wiith no change in tone or pitch. No dash lights illuminated and no codes have been generated. Sunroof was closed.
The whine seemed to come from behind the instrument cluster, perhaps a bit lower. The frequency reminded me of a small bearing failing yet the tone was much softer. When I came to a stop so did the sound. Coincidence? Can't tell as it did reappear briefly again 35mph then it stopped while still at speed. Poking around in the engine bay while at idle doesn't reveal anything. I replaced both front hubs several months ago while doing the GMT800 to 900 brake upgrade.
Today's drive with similar conditions was uneventful. No tone was heard.
Has anybody else experienced this in their rig or have a guess what could create the sound?
Marky Dissod
How did the sound behave AS you were COMING to a stop?
Why do I think it was your afterblower?
Roilux
Roilux
Senior Member
Burbank, CA
It started as a soft intermittent stutter the first time, remained almost continuous and then abruptly stopped as the vehicle slowed down. The second occurrence was more 'on' then 'off' while at constant speed.
Marky Dissod
Stumped.
After you give the steering & suspension a good twice over, switch attention to the HVAC.
'fraid those are my best guesses for now.
Roilux
Roilux
Senior Member
Burbank, CA
Stumped.
I've new suspension and steering components up front as of last year. Only the steering box, torsion bars and bar bushings are original. I'll give it all a good once over as it's easier to be under the vehicle than it is under the dash. :/
Bart
Houston
My 2012 Tahoe LS has done something similar recently. Noise went away after restoring the refrigerant charge in the A/C system. This might be something you could check.
Roilux
Roilux
Senior Member
Burbank, CA
Thanks all. Noise coming from the fuel pressure regulator was mention in a fuel pump thread.
I've since replaced the regulator, then fuel filter and finally the fuel pump when line pressure remained low. I've only made three short trips since then and the tone has not returned. Huzzuh.
BadDaddy2003
