2021 Z71 Air Suspension Help Please
Blue88
Hi All,
We have a 2021 Tahoe Z71 with the air suspension. Love the truck, but the system's compressor seems to freeze up when it's cold. When this happens, I receive the "maintenance leveling system" error. By cold I mean under 10 degrees Fahrenheit. By the time we bring it to the dealer, it has warmed up and been working properly, so they're of no help. My family is stuck up in VT with a 4+ hr drive home this time with the front suspension at full drop. The closest dealer cannot get us in for weeks.
I have pulled fuses 61, 68 as well as left the negative cable off for an hour with no fix. I'm actively trying to find a garage I can toss it in for an hour to see if that will resolve the issue. In the meantime, do these systems have manual fills like the retro-fit systems available for classic cars? If anyone has any ideas on how to force air into the springs I'm all ears. Thank you!
Antonm
Our 23 high country Tahoe (with air ride) has a capped port on the air tank under truck that could potentially be used to add air to the tank. Unfortunately its a weird connection (kinda looks like an AC line connection but different size), its not just a normal Schrader valve style connection.
If you could source the correct fitting to connect to that capped port you could add air to the tank from a small external compressor (like one of these little cigarette lighter plug in tire inflator compressors).
POST EDIT:
Little googling around didn't find me the name or style of that connection, but below is a picture from an eBay listing for a factory air ride tank. The black capped connection I'm talking about is visible on the left side of the tank
Welcome to the Forum from NH.
Pics of the truck, please.
This is the first post that I've seen about outside temperatures and the truck's air compressor. I know that your need for a solution is rather immediate, and the above post from @Antonm may be your best bet, assuming that a local shop can figure out what that connector is. I assume that your truck is still under warranty, so your longer term solution should be achieved without additional cost to you, and I'm guessing that a compressor replacement will be the first attempted fix.
B
Blue88
Thank you both so very much! The local shop is too afraid to add air to the system . I’ve worked on cars my whole life and it’s so frustrating being on the other side of this haha.
We’re in for a bumpy ride I guess! I will report back once it’s fixed. May even have to make my own water separator for the system so this doesn’t happen again.
Kpwweb
Alldata states to fill that tank (shown above) with 210 psi of nitrogen using a special fitting.
Antonm
Did Alldata give the name of, or perhaps a part number for, this special fitting?
I'd be interesting in getting one of these fittings too, that way I could use the Tahoe's onboard air system to fill up river floats or a camping air mattress.
Antonm
I wonder if something like this off Amazon would allow us to tap into, and use the air from, that port on the factory air ride tank?
Anyone out there wanna be the guinee pig?
Kpwweb
See attached. They called the tool a CH-52667? Also attached a tsb. May be op’s original problem?
  • TSB - Air Suspension.pdf
Antonm
I'll be damn ,,, it is a r134a refrigerant fitting on the tank.
I googled that part number and found one of those tools available for sale (costs $1600, um no thanks) , but reading the description sure was interesting, below is copy/paste for the description of that tool (see bolded and underlined section for the interesting part)
CH-52667 Nitrogen Injector Kit GM-52667
This tool is designed to inject nitrogen into the air suspension air springs and air tank. When servicing a component, the system loses air, and the onboard compressor cannot fill the entire system.
An adapter will be used on the “Wonder Valve” fitting of the air spring and an R134a fitting on the air tank. Nitrogen will be used to achieve the air dryness specification and to inject specified pressure into the air springs and the air tank. This will also prevent any oil or debris from entering the system.
The kit contains:
  • CH-52667-1 Regulator Assembly
  • CH-52667-2 Port Assembly
  • CH-52667-3 Fitting Assembly. Adapter for the “Wonder Valve” to be used with the air strut.
the above was copy/ pasted from this website
BainMan
Did you get it fixed?
Got a '21 with a drooping rear after sitting for a couple days, trying to locate the leak.. Connections on and around the pump and manifold seem solid, passed the soapy water test at least.. Learning about the nitrogen fill today, looks like I won't be swapping out air springs on my own, or at least require a shop to top it off after..
If you dug into this on your own (or anyone else) is there any way to remove the dust shields from he air spring so the air spring can be tested? Trying to figure out which side is leaking!
That member hasn't been on here since mid-March, unfortunately.
BainMan
Yea I saw that... Hoping an email notification might draw him back! But I understand that's wishful thinking... This air ride setup is more complicated than the last gen!
kbuskill
NE. FL.
Just FYI, the plastic accordian looking dust shields can be pulled off without any issues.
I bought an entire set of these air struts and completely disassembled the front ones to modify and install them on my '08 Suburban.
I still have the rears untouched if you are interested in them.
BainMan
That's awesome you got the front's to work on the 2008! I just might hit you up to discuss the rear air shocks you have sitting around!
The air shock has to be completely removed from the vehicle to pull that plastic dust boot, right? I've got Friday off work, likely targeting that day to work on it.
Did you get the special tool (CH-52667 Air Spring Inflator) to add air to the shock prior to removing the jack stand and letting the vehicle sit on the ground? Or how did you get around that?
kbuskill
NE. FL.
When I got these they were already removed from the Escalade they came off of. I installed a short piece of 1/4" DOT air line with a shrader valve for testing purposes so I could air them up off of a normal compressor, like filling a tire.
These have like a safety/check valve built into them so if the air line should get ripped out the valve closes and you don't lose all the pressure in the bag. The air line essentially depresses the valve when inserted.
Chitragupta
I have a RAM 1500 with air suspension.
I’ve never had any issues with my air suspension but over on the RAM 5th Generation forum under their “Suspension” forum they do say to only use nitrogen to refill the system.
I’ve also seen threads where someone has found on Amazon HVAC refringent couplers for not that much money that fit the RAM nitrogen charge fittings on the tank.
YMMV
CRN_25
