No reverse on 2022 Yukon
Yukon-Steve
Purchased a 2022 Yukon Denali with about 65k miles on it about a month ago
All good for about 3000 miles, now won’t move in reverse. The “R” shows up fine as expected in the dashboard when the reverse button is pressed, and the backup camera goes on, but the car does not move in reverse. The engine seems like it is in neutral. Now also getting an engine light (yellow steady) and an onstar diagnostic message saying transmission problem. Have service appointment Monday. Any guesses? Will post findings.
B-train
I thought there was some known issues about the valve bodies in the 10 speeds. Maybe that's what they'll find.
jfoj
Sounds like an internal transmission problem. Maybe you can get lucky and there will be a valve body solenoid wire that came disconnected. Otherwise it will likely be more involved, as mentioned either valve body or maybe a clutch pack. I have not studied up on the 10 speed, so do not know if there are sprags for reverse as well.
Generally a generic OBDII tool can read any code that triggers the SES/CEL/MIL. It might give you a clue as to what may be going on?
RG23RST
If you don't know anything about it then why speculate?
OP, do you have an extended warranty? If not I'd suggest taking it to an independent transmission shop but that's me. Good news/bad news is it's not an uncommon failure mode caused by pressure bore wear. At a dealership level GM will not allow us to use an aftermarket "fix" that will most likely solve your problem assuming it's failed in the same way all the others do. Sometimes you can get lucky and clear the stored DTCs and it'll be fine for awhile. GM will only replace the full valve body assembly and they're currently very hard to get in short order for the gen2 10L80.
If you're out of warranty the next gen kit for a gen2 ERS transmission is about the same cost as a valve body from GM. Get it tested for pressure bleeds and go from there.
jfoj
So you understand my background and experience?
No speculation here, I think I gave pretty solid advice.
The only thing I do not know 100% with the 10 speed is exactly how reverse is obtained between clutch packs/bands/sprags/planetaries.
Could be a hard part failure as well.
Best thing to do first is read and understand the OBDII error code and use this as a point of reference to start from. Search any tech bulletins and if this is a "common" failure, any shop that has addressed this before will likely know what the "common" failure mode is and be able to give the OP the "bad news" before they even pull the vehicle in the shop.
DuraYuk
If a shop is diagnosing things before they pull it into the shop based on previous assumptions run far far away from that place.
That's not how you diagnose anything
blanchard7684
Senior Member
Sounds like either a reverse circuit solenoid is not moving the valve , the valve is stuck, or debris is restricting flow.
jerry455
#PIP6008C: 10L80 DTC P2714 - (Jan 24, 2025)
Condition
DTC P2714, with or without reverse engagement.​
Cause
The (500) Input Internal Gear may have separated from the (501) Direct Overdrive Sun Gear Shaft due to the (502) Input Internal Gear Retainer Ring being dis-lodged on transmission assemblies built at the Romulus Assembly Plant between Julian dates 24158 thru 24249. See SI Doc ID# 4356498.
Correction
Perform an internal trans inspection to determine if the R2S3 retaining ring is dislodged (Item #502) to replace the retainer if found dis-lodged.
petethepug
Michael
SoCal
Poor guy asked for a guess of what might be going on, therefore nobody’s wrong and drinks on the house until the truck is scanned.
Y
Yukon-Steve
Ended up replacing the transmission. Dealership tested many things, then said it needed replacement. related to major failure with reverse clutch (sorry I don’t know more). Now new transmission throwing a code
P187E Park Valve Stuck Off
Seems to run fine, and tested on a hill that park is holding (with electronic break off). So I assume it is just the park sensor and the actual park valve is working? Can I live with this internal code?…and not take it back to the dealer? dont want to loose the use of the vehicle, the dealer had it for 5 weeks. No engine light showing and on-Star Diagnostics says all systems good. If I didn’t read the code I wouldn’t know it.
jfoj
So you should review page 5 of the Service Bulletin in the first link below, while not specfically for the 10L80 or your model, it pretty well outlines what to do for the code you are getting. Seems that the valve body would need to be replaced. Be careful reading the bulletin as the paragraphs indicate and reference codes "above". The paragraph you need to read is on the right side of page 5.
The 2nd link below has a good coverage about the overall issues with the 10L80E, but there is a part specific to the P187E as well.
While the transmission was replaced, it was likely a "factory remanufacturered" unit. The issue is GM is having MASSIVE valve body problems with the 10 speed transmission. I expect a recall for the same rear wheel lock up to be released for the gasoline trucks and SUVs soon. The recall is really not a "fix", it is a TCM software flash to put the vehicle in "limp mode" to keep the transmission from shifting above a certain gear to prevent rear wheel lock up once a specific trouble code is detected. There was just a recall for this software TCM update released for 90,000 Cadillacs and Camero's with the 10L80 transmisson a few weeks ago. This recall is only for the TCM flash, but as part of this recall, GM is extending the valve body warranty for 15 years, 150,000 miles. See 2nd link below.
In the short term, I would highly recommend ALWAYS using the parking brake until this problem has resolved.
The main problem at the moment is valve bodies are not available. There have been vehicles sitting for over a month waiting on valve bodies.
If it was me, I would likely just get a NextGen valve body kit and either DIY or have a local shop put this in. Even if the current issue is fixed, hard to say if you would not have other problems in the future due the valve body internal leakage issues and wear problems that the NextGen Valve body kit address. It would hopefully fix the problem, but while the valve body is out the valves, sensors and wiring can be inspected for problems and addressed as needed. See 3rd link below.
There could be a wildcard issue here as well. Apparently there are a few different valve body options with and without a default solenoid and with and without electronic shifting. The without default solenoid is for earlier years 2018-2019, not sure this would apply here and what the solenoid was for. But the difference between electronic shifter and mechanical shifter could possible be an issue here? I do not know all the ins and outs about the differences, but there are differences. Possibly the wrong transmission was ordered or the wrong valve body was put in the transmission? These are just things to think about. I am not really impressed with the OE rebuilt transmissions as I do not think valve bodies are really reworked and tested like they should be. This may change with the rear wheel lock up problems, but maybe not?
Good luck and let us know what you do and what happens.
Service Bulletin 21-NA-169
10L80E Info
Valve Body Bulletin
Post with info about NextGen Valve Body Kit
GS Audio
