front crossmember bolts: TTY and part number
persistent
i recently dropped my oil pan as part of a dod delete, and i'm in the process of reinstalling the parts i had to remove to get it out, which includes the front crossmember. i am following the service manual and see that the 4 bolts that secure this crossmember are supposed to be installed at 52 ft-lbs first pass and 110 degrees second pass. this typically indicates the bolt in question is a TTY bolt and needs to be replaced rather than reinstalled. am i right to assume these bolts need to be replaced?
in addition to not being clear if i need to replace the bolts, i also seem to be unable to find a part number for the replacement bolts and nuts. i can easily find the front crossmember part on gmpartsdirect, but not the corresponding bolts. i found a prior post on here about a similar issue that appeared to be left unresolved.
the hex bolts have an integrated washer, require 18 mm socket, 135 mm length shaft, have "SFT 10.9" on the head, roughly 12 mm diameter on threads, and only bottom 45 mm are threaded.
thanks for reading
Big Mama
Virginia
@915_Tahoe may know the part number for them. I can’t help with you being able to reuse them. You might also check with a local store that sells fasteners. We have one here that helped me find odd size/purpose bolts. Your dealer may also have them.
915_Tahoe
Your GM Parts Specialist
HELL PASO, TX
thanks for reading
What's theblast 8 of the vin#
P
persistent
Front crossmember bolt
Gm#11517236 x4
Frnt crossmember nut
Gm#11516078 x4
I don't see these are required to by replaced with new. So you should be ok to reuse.
thanks for the input.
i did confirm that specifying a torque angle does not always indicate a tty bolt, but it usually does. i learned that the utility of specifying a torque angle is that it corresponds to a more accurate clamping force than a torque spec, and i guess that matters more than usual with frame components.
these crossmember bolts and nuts were super dirty. after some brakleen and wire brushing, i was able to confirm the threads didn't look particularly stressed.
