Back up lights
Jimbo48
I have a 2024 Tahoe RST. The Reverse Camera at night looks like is in Infrared. When i use the side mirrors there is no light to speak of. has anyone found a way to put more light in rear when backing up?
Punteh
I saw this pop up somewhere recently. Thought it seemed like an intriguing idea. Might be kind of challenging to connect it on a Tahoe/Suburban/Yukon, definitely more so than the trucks they show them on. I also wonder if it might affect the camera a little bit since it would be mounted directly below the camera
My 2007 Yukon XL Denali had terrible stock backup lights, and I have stone walls on either side of my driveway. So, I changed them to LEDs. That change made the backup lights only half terrible. So, I attached a pair of LED strings under the rear bumper, and that solved the back illumination issue.
harlamert
I agree the reverse lights are terrible
I added 2 slim 6 inch light bar to the under side of my bumper and used the factory reverse lights to switch the relay to turn them on I didn't want to add switches inside the cab
harlamert
Here are some pictures
J
Jimbo48
2 Questions: What year vehicle and what brand/model? Thanks for replying.
J
Jimbo48
I read that LEDs throw a code on 22-24 Tahoes and Subs, any issues?
RST Dana
OH
If you use a relay, you won’t need to worry about codes.
Conedaddy
