Big 3 Wire size
SpareParts
North Idaho
Tried searching but nothing much came up so im doing it wrong I guess.
Anyway, I want to upgrade my power and ground wires. Pretty much all of them.
I have about 10 feet of 1in wide ground strap so that part is pretty covered I think.
What is the suggested wire size for the power and ground wires?
wjburken
Eastern Iowa
2 GA or 1/0 is what I’ve seen people mostly use. Others might have other thoughts.
homesick
The Best Me I Can Be
Navy Air Force
I've used 6 ga a few times, from the battery to the amp, with no troubles. 2 ga strikes me as overkill, but I could be wrong; and it sure couldn't hurt.
joe
SpareParts
SpareParts
North Idaho
I did a 1998 K2500 suburban a few years ago using 2/0 welding cable. I had about 20ft sitting around for a few years doing nothing so it only cost me Lugs to solder on.
It was overkill I think, Now that I have to buy wire im not sure if i wanna pay for 20ft of 2/0 welding cable of it's overkill.
I'm not going to have anything requiring high amp's, Maybe a hidden winch, but that's a whole different matter.
wjburken
Eastern Iowa
6 ga is pretty big, but I wasn't arguing.
joe
Didn’t take it as an argument at all.
6 ga should handle 95% of what people are doing.
SpareParts
SpareParts
North Idaho
I have a 145 amp alternator, so im thinking 2/0 from alt to battery then 2/0 from battery to starter and probably 2/0 from battery to engine block and maybe 2/0 from battery to the under hood fuse box.
4 gauge for everything else.
PPV_2018
Molon Labe
U.S.A.
nothing wrong with 2/0 if you’re trying to really beef up the electrical system and have real deep pockets.
1/0 would still be plenty good upgrade compared to any factory set up and still would be plenty adequate plus some for virtually any type of load you could think of. make sure it’s 100% copper cable
j91z28d1
the 145amp alt isn't a lot of power in the days of stock 220amp ones now.
I'm personally not a fan of the big 3 wiring that I've seen where they just add big cables over the top of the factory wiring. especially if there's not a common problem with the factory wiring or you're doing something that requires more power. I prefer to replace factory wiring with either just new, or you can upgrade to thicker if you want.
I don't know of any common undersized wiring issues in these trucks stock. besides when they get corroded up and need replacement or grounds make bad connection. but replacing with stock parts fixes that and shouldn't really be covered up by adding wires. there's also the current sensor to consider, make sure your added wires aren't bypassing that. the ecm uses that to control your alt output.
just my 2 cents.
SpareParts
SpareParts
North Idaho
I'll be replacing the factory wire with larger gauge wire. I would never add a wire over another wire, seems like the wrong way to do it to me.
The one OBS I did before was an improvement for sure. Brighter headlights, spun over better, Heater seemed to blow a little harder. Only a slight drop in voltage front to rear.
I think it's worth it.
Maybe not needed but fixing it up is a hobby so why not.
4 gauge is typically what the larger stock wiring is so anything thicker is an improvement I guess, provided it is crimped properly with the correct size firings.
j91z28d1
ahh yeah, can't hurt. when I see big 3 wiring I think of this kinda kit.
it literally a wiring kit that lays over the top of engine and hooks to different points. while leaving all the factory issues in place. mainly on that car the atl wire is little bigger than 8g which is great but has a 14g fuse able link right at the starter near the headers. from there up to the battery and the rest of the electrical system. it's an awful way to do it. so much voltage drop the alt output is not ecm controled, it references the fuse box pickup. so you might see 17plus volts at the atl lug and 13 at the bcm when the fan is on. it's pretty bad.
waveryd
IL
I just did a dual battery conversion/ battery cable upgrade on my 2004 Yukon XL. I used 1/0 tinned marine battery cable with crimped on tin plated copper lugs. Also used the military type battery terminals and heat shrink tubing to seal the ends
. I got tired of dealing with side post batteries. I had previously added electric radiator cooling fans. When idling at night with two radiator fans running, two air conditioner fans running, and headlights on the factory electrical system was at its limit. Hence the Mechman alternator,
dual battery and cable upgrade.
j91z28d1
just a tip, when adding electric fans or upgrading to one's that pull more. get the power for the main relay stright off the alt lug. it's the highest voltage point and keeps the load off the factory working.
I have found even if you have weak factory working, if you remove the 40amp or more fan load off it even when it comes with factory fans and run it straight to the alt and a good engine found. the factory stuff works much better. same for if you even need to run big fuel pumps. take the load off the factory stuff and pick it up from the alt directly.
j91z28d1
What size is the OEM cable from the factory?
gm uses metric to show the area of the wire, something like cm/2. a manual will give you the size in cm/2 and then you chat Google the closes sae size. but it's a little smaller than 0/2 last I looked.
johnsonwillie199
