Helix Amps - Anybody installed one of these?
jeportera
I just purchased a Helix P Six amp that I'm planning on installing in my 2022 AT4. I was going to go the harness bypass route to get the Bose factory amp out of the picture, but now that PAC has released the AP4-GM71 unit I'm going to use it instead to get the signal to the Helix. For the front stage, I'm planning on using Audiofrog dash speakers and Karma Audio 6x9's in the front doors. Rear doors will have Audiofrog coaxials, rear panel will remain stock for now. The 6 channel Helix will power the front stage and rear doors, and at some point I plan on installing a seperate small amp to power the rear panels but for now they'll be unhooked. For the low end I already have a JL RD1000 pushing a JL 10w7 in the sealed enclosure. I'm planning on getting some help on the Helix tuning once I've installed it, but I'm curious if any of you have gone down a road like this and if so do you have any tips or advice? I also plan on doing some decent sound deadening in the doors as well.
I have not used that brand of amp, so I cannot offer any advice on that. When I upgraded my audio system, I removed the rear post speakers, as they were too small to be really useful. Since I almost never have more than 2 people in the truck, I focused on the front door and post speakers and the second row door speakers, and I do not miss the rear post speakers. With decent tuning of the head unit's pre-amps, you can get all the spatial depth of sound you need with just the 4 door and front post speakers.
Not sure how much that amp is I used a idatalink maestro rr with my aftermarket head unit and factory + amp and subs and I retain the bose dsp + obdii code reader built in and gauges
Joel_S
The p6 is an absolutely fantastic amp. I’m a former helix dealer through my previous employer.
Ditch the JL amp (even though great) and get a p one to match the p6. 2 ohm load on the w7 would be 880 watts or 1 ohm load is 1500 watts on the p6.
If you’re going to run Andy’s speakers, you could do GB25 with some brackets in the dash, or GS25 as they have brackets to be drop in speakers. I still prefer a separate tweeter ontop of those but they still sound great without one.
However for me personally, focal > AF.
Don’t waste your time with the third row, placement up in the pillars never leads to great sound unless you just want loud. You would need more processor and SO much time alignment and the levels to be set so low it wouldn’t be worth doing. This means your gonna either have to run a second Dsp in addition to what the p six can already do, or run a larger dsp feeding the p six (redundant) and your sub stage and rear stage. I’ve never missed them in any Tahoe/yukon/esky I’ve done.
Find a good local tuner you like and go with them after you’ve vetted them, or there’s always Nick A with Resonix who’s a fantastic tuner. I’ll be having him remote tune my
M5 when I finish that.
I'm a Focal fan myself, with them installed on my other car.
My M5, A4 avant, A6, 07 Yukon, and wifes 330i and 16 Yukon were getting rid of all have focal in them. Her 16 was put back to stock however to trade.
My Focal speakers are also on their second car. No need to give those quality and long lasting speakers away. I just moved them to the next car purchase.
moto
