Should I replace all coils?
tdebacker
I recently had #8 coil go bad on a road trip to South Dakota. (Vehicle is 2017 Suburban Premier 5.3 for reference) I usually do my own work, but this thing started misfiring and popping up like 15-20 codes so I dropped it off at the dealer. I was fully prepared for it to be a computer or something expensive.
I get a call later saying #8 coil was bad so I had it replaced.
I changed my spark plugs/wires around 97k and I'm currently at 140k.
With GM engines, if one coil goes bad, should I replace them all or can I just replace the one that went bad?
normally coils last a really long time you should be fine with just changing the one out.
otherwise you would read about issues with them often and this is simply not the case.
Dh1280
