Should I replace all coils?
tdebacker
I recently had #8 coil go bad on a road trip to South Dakota. (Vehicle is 2017 Suburban Premier 5.3 for reference) I usually do my own work, but this thing started misfiring and popping up like 15-20 codes so I dropped it off at the dealer. I was fully prepared for it to be a computer or something expensive.
I get a call later saying #8 coil was bad so I had it replaced.
I changed my spark plugs/wires around 97k and I'm currently at 140k.
With GM engines, if one coil goes bad, should I replace them all or can I just replace the one that went bad?
normally coils last a really long time you should be fine with just changing the one out.
otherwise you would read about issues with them often and this is simply not the case.
The Whip
