Tahoe Fog lights
Koolaid6666
Looks Like the 25 high country comes with fog lights not sure off the other models.
jerry455
I was leaving work, I work at the GM Global Tech Center in Warren MI, and I stopped as I drove past a new Suburban. It had a set of fog lights on it. I never noticed it before. I will have to look in the parts catalog to see the assembly. It looks like it is a new black plastic piece of the lower grille and where the ends are there are round fog lights.
Trellis
Yes fog lights were added to the 2025…I’m jealous
Kpwweb
Any update yet?
Not yet. Contacted the company. The fog lights were on backorder due to large holiday demand. Hopefully within a week I should have them.
Kpwweb
I got them Wednesday. Been traveling so haven’t had a chance to put them on or try them out.
Kpwweb
I installed the right side yesterday. I got the model that mounta above the recovery hooks, so cutting was required. See pics. Sorry for the long process.
Kpwweb
I’m going to have to post the rest of the images tomorrow—site doesn’t like my heics on my phone.
Kpwweb
WalleyeMikeIII
Sunny and Snowy Minnesota
The look great, but pretty much rendered the tow hooks useless, or at least at high risk of putting your fog lights in harms way if you were to use a shackle or a metal hook.
With a strap with loop ends, you may be ok.
Kpwweb
There is a little more room than what shows in the photo, but it is somewhat crowded there as well. I was told they may be working on actual clevis hooks, like the at4x has. I should also say they have the same setup that snaps in the grill instead of mounting above the tow hooks, leaving that area completely stock.
h0m3w3CkeR
Virginia
Has anyone purchased these for the RST or similar models? Considering these since its the only option I have at this point.
Tried installing some in the same area, and on the passenger side there is a small short range radar sensor an inch behind the panel.
Keanen55
HOUSTON, TX
I ordered a pair of these over a month ago! Anyone else dealing with how slow they are on shipping these out?
h0m3w3CkeR
Virginia
The other day I did a google search on them, and thats on par with what I read about them. They will continuously give you the run around, make excuses, and avoid your calls. After reading up on them, I'm avoiding them at all cost.
Keanen55
HOUSTON, TX
Yeah, I think I'm going to file a claim with my credit card company. I'd warn everyone to avoid this vendor! Seemed like a good deal at the time!
Kpwweb
Have you called them? Mine were slow, but I talked to them several times.
Ossipeelake
