because your pushing the big pedal, try granny style @55 and minimal braking, ease on the pedal like you are going to take all day to get up to speed. coast whenever possible.Why does my 2010 Yukon Denali 6.2, only get 13 miles per gallon?
'Cause you drive it like you stole it?Why does my 2010 Yukon Denali 6.2, only get 13 miles per gallon?
Even if it is not an XL, it still weighs at last 5000lb. (XLs weigh closer to 6000lb.)Why does my 2010 Yukon Denali 6.2L, only get 13MpG?
Lol, what about me...Something's wrong, you should be getting a lot better mileage. Our 2014 with the same L94 averaged 17.2 MPG until I deleted the AFM/DOD at 142,000 miles. (After the delete, running the Diablo sport economy tune, we're at 168,000 mi with an overall average of 18.8)
How's your air filter? Spark plugs? Any codes stored? If the basic stuff checks out, I'd throw a new AC Delco camshaft position sensor in, and crankshaft position sensor. They are known to go bad without throwing a code. The L94 does not get good mileage from the AFM/DOD system.... It gets it from variable valve timing, which depends on the camshaft position sensor to work properly. (Which works in tandem with the crankshaft position sensor) With its ability to retard camshaft timing at lower RPMs, you make a lot more torque which equals more efficiency right where you need it, at cruising speed. That's my guess anyway
If you were any more leadfooted, you'd be thorium-footed.Lol, what about me? I get 9.6MpG, what's your synopsis? I wanna hear this one.
Did you forget you've got 15 bags of cement in the trunk? LOL.... Must have a serious leadfoot?Lol, what about me...
I get 9.6, what's your synopsis I wanna hear this one
.... So something's definitely off. We use 92 octane on long road trips, like the 900 miles to Vegas and it nets us 20 MPG. I'm wondering if you're getting close to having the catalytic converters plugged. Maybe not enough yet to set the code. How old is the muffler? Did the plugs look good when you changed them? Wouldn't hurt to plug in and check the fuel tables and such...I'll add the vehicle runs perfectly the tires are inflated properly and transmission is in good working condition, spark plugs/wires have about 10k on them or less and I use 93 octane
City Or Highway ??? what kind of driving and temps and where ????Why does my 2010 Yukon Denali 6.2, only get 13 miles per gallon?
Yep ding ding, it's all about the bid pedal same for the opDid you forget you've got 15 bags of cement in the trunk? LOL.... Must have a serious leadfoot?
Cats are new less than a year old each, it's none of the above, it's just how I drive. I can take a brand new one off the lot and get the same mpg.... So something's definitely off. We use 92 octane on long road trips, like the 900 miles to Vegas and it nets us 20 MPG. I'm wondering if you're getting close to having the catalytic converters plugged. Maybe not enough yet to set the code. How old is the muffler? Did the plugs look good when you changed them? Wouldn't hurt to plug in and check the fuel tables and such...
