best mods so far...
KMeloney
don't think it does. you can just unplug it whenever you need any testing done. and plug it back in after. I live in California and was worried about CARB compliance, but it's not an issue.
Did I read on this forum somewhere where the Carbyte unit doesn't engage the fuel management delete function until you've reached 40 mph? (And then it's engaged for the remainder of the engine cycle...?) Is that true?
ZKWBQD
SO I've spent a lot of time and money on trying to make my 2023 Yukon Denali sound and perform its best.
I'm super picky about sound particularly and have tried 5 different mufflers from Magnaflow, Flowmaster and so forth.
I finally found the absoulte BEST muffler...BORLA Pro XS Universal Muffler (#40359)
Makes the truck SOUND how it's suppose to...nice deep rumble, NO DRONE and you really can't hear too much from the inside.
Sounds SO GOOD and I am so happy and wanted to share LOL.
For $115, it is easily the best mod for all of US without going full catback, which is WAY more expensive.
Also I researched Pedal Monster, Pedal Commander, RANGE DFM disabler, and I came across CARBYTE by OBD Solutions.
WOW what a REAL difference this makes. Full V8 MODE at all times, no coasting issues. Also disables the auto start/stop 100% of the time.
The power band of the truck feels much more linear and throttle response has improved. I'm sure I may lose some MPG but let's be honest, we don't have these vehicles to be "fuel friendly"
Just wanted to share my thoughts and experiences with these products! Cheers All~!
I immediately did several things. I permanently disabled engine Stop / Start. This will improve engine life, as well as safety. I also disconnected the daytime running lights. I can turn them on manually if I want to, but two government studies have shown NO safety benefit to driving with your lights on during the day. It improves the looks tremendously, my car no longer looks like a Christmas tree going down the road. I changed the circuitry to the cigarette lighter aka power port, so they are on all the time. Modified so that the vehicle will idle for more than 20 minutes and accessories can also stay on for more than 20 minutes (I need this for Drive-In movies). I consider everything I've done as correcting design mistakes in the vehicle.
A
ACHUN717
No not true...from the research I have done and through my own experience it does not seem that way. I know the RANGE disabler had a coasting issue, the Carbyte does not, it's full V8 mode 100% of the time. They do have a solid return policy, i recommend trying it out for yourself!
Flugzeugfuhrer
IIRC, the CarByte is made by the same folks as OBDLink. Very tempting, especially now with Black Friday deal at the South American Jungle Store.
14point5
NE Ohio
I downloaded the OBDLink app in the Apple app store but it doesn't recognize the Carbyte unit. I thought I read others here were able to make both work.
A
ACHUN717
I think the website confirms that it kicks in after 40mph.
Check out some of the carbyte threads on Reddit. The founder is on there and gives some helpful information. From my own experience I feel like DFM is disabled at all times and all speeds. I could be wrong.
PPK_
Oklahoma City
I have one installed for two days… after a few minutes to warm up.. you no longer see 99 in the miles per gallon… when you let up. Maybe you see 70 or so.. it does work after 40 mph too.. auto start killed off too…
Horay!!!
Agent WD-40
here you go!
best sounding muffler by far, unless you want something REALLY aggressive.
also have KOOKS shorty headers which may or may not add to the sound...can't be sure lol
Do you have any driving clips - either inside out outside the vehicle?
Sounds really good and seems like it stays fairly tame.
How much do you hear this just driving around town or on highway? Do you hear when the DFM turns on?
A
ACHUN717
I don’t but I’ll try to post some soon. I do hear it driving around town and highway. It’s noticeable but not obnoxious. I have 3 small kids and it doesn’t bother them.
1badtahoe24
What other mufflers did you try from borla or corsa
A
ACHUN717
Tried the borla xr which was way too loud
Haven’t tried any corsa mufflers
had two different magnaflows, the 10416( also crazy loud and too much drone) and I also had the 11225(low tone, but didn’t sound nice)
Also a few generic brands but none worth mentioning.
The borla xs I have now really makes the best sound, barely any drone. And just sounds how our trucks should sound.
Def saves you money on cat back. Way cheaper and honestly just as good a sound. And you can use the money you saved for something else! If you were local in Los Angeles I’d have you hear in person
1badtahoe24
Okay great thank you for the info. ℹ️ just can’t justify spending $2000 on a cat back system. I’ll give your muffler a shot. Probably get the tips blacked out too.
A
ACHUN717
Yea I agree. That’s way too much to spend on something that doesn’t really give that much of a performance boost. I got some MBRP carbon fiber exhaust tips installed at the muffler shop. Looks clean.
wsherring
I had a shop cut out the stock muffler and valve today and and put in this BORLA Pro XS Universal Muffler (#40359) on my 2023 5.3 Suburban with single exhaust. The drone inside is waaay too loud at 1800-2200 rpm. I don't know if it's because of the single exhaust, the stock turndown tip that's under the rear, or what, but I'm gonna have to figure something out to get rid of the drone. Either a resonator in front or swap it out for a different muffler.
Sam
bmbentley
Northern VA
Here's a quick clip of the CORSA Performance Sport Catback Exhaust I just put on my 2025 Yukon XL AT4 Ultimate ( 6.2L ).
jerry455
That is why I am hesitant to change anything on the exhaust. I hear all of these trucks and they sound good, unloaded, but I pull a travel trailer several times a season and I can imagine they would drone at certain RPM's. I have the stock 4 tip exhaust and it sounds good, maybe a little quiet but I am not ready to change it yet.
spartan1984
Hey fellow members,
Newbie here and trying to educate myself. We'll be purchasing a 2023 Tahoe RST (5.3L) and looking for a better exhaust note (growl) and improved engine performance. Been reading this forum and curious about the Borla vs. Corsa debate and this thing called CarBYTE.
For a more "muscular" exhaust note, seems like just the muffler will work (vice purchasing cat-back). Thoughts on this?
CarBYTE...help me better understand why I would need something like this.
Thanks for your time,
Barry
BacDoc
Vero Beach Florida
Hey fellow members,
Barry
The Cat back system will run $2000-$3500 and may give marginal increase in HP/Torque but most drivers will not notice it. GM performance exhaust system is around $3000 and they claim increased HP/Torque so they must have done some testing.
If you just want the better sound just switch the muffler and/or remove resonator. This will be cheapest and even if you have a good shop you can try a couple different mufflers and still be way under the price of a cat back system. Purists will say the cat back system is the best way to go.
I am interested in the carbyte simply because it disables the auto stop feature that is so annoying. Yes you can just push the button but I think it’s worth it just to get rid of auto stop and any thing else is just a bonus. From what I understand it is plug and play with absolutely no modifications needed.
spartan1984
BacDoc,
Thank you and appreciate the Intel on the exhaust/CarByte. As you mentioned, I'm inclined to do the muffler vice the cat back system. Good to hear CarBYTE is a "plug and go" system...definitely don't want to get into "tinkering" with any engine mods.
Barry & Shelly
BadDaddy2003
