seats.
beatup01
DFW, Texas
I'm looking to get specifically my driver's seat repaired/replaced, and i was curious, should I just go to a junkyard and find some seats, should i just get covers, or should i reupholster. im trying to find the best solution money isnt an issue
Welcome to the Forum from NH.
Pics of the truck, please.
I suggest that you check out the Seat Shop, where you can get a replacement foam cushion and the leather cover.
Tahoe14
Central Fl
You could go to a junkyard but they are probably going to be worn like the ones you have. I would reupholster it and install new pads while you have it out and apart.
Tonyv__
Bucks county PA
I bought this years ago and was very happy with it. The listing is still active. I don’t have the truck anymore to tell you how it looks today. I recommend getting the cushion as well, also obtainable on eBay.
beatup01
beatup01
DFW, Texas
here are some pics, and i will check that out!
I'll have my Hoe for a good long time and got my stuff at The Seat Shop a couple of years ago -- new OE style bottom cover, seat cushion, and heater pad. If you don't use the seat heater you could get by without a new pad, but getting the old one off (and assuming it's in good enough condition to last, and it survives the removal) will be a hassle.
Pics of my work here:
You can get by with less expensive parts if that's the way you want to go. Others will have some less expensive suggestions.
mattbta
Frisco, TX
The Seat Shop is up in Allen (wait, they are in Plano now) and lots of folks source covers/foam from there. I believe they also install.
SDR_John
Hi Fless,
I have an 03 Yukon XL with heated seats... I'm looking at a new cover and cushion... will I be able to re-use my heater elements? or are they stuck to my old cushion? Thanks!
Hi Fless,
When I did mine I toyed with the idea of using the old seat heater, but in the end decided that it would be easier to just get a new heater. The old one was pretty stuck to the old foam and I didn't want to take a chance that it couldn't be used, or that it wouldn't lie correctly on the new foam. Between being old and having to remove it from the old foam, it may not survive (it had lived a long and productive life!). It would be my luck that it would stop working right after I put it all back together.
Bentley95
