2022 Escalade; Why wont it stay LOW??
trdhulk
Just got a 22 Escalade Sport Platinum. The air suspension raises by itself when driving and stays raised until you slow back down or park.
How do I keep it low while driving? It looks SO much better low.
Normal ride height:
Lowered "parked" height that I want while driving
The roads here are full of potholes they ruin wheels easily.
the caddy doesn't have a manual ride control setting?
soulsea
Bar
What it looked like on mine:
trdhulk
trdhulk
How much does it raise from there when you drive it?
soulsea
Bar
It raises the same amount as stock, it just starts from a lower height.
I had mine roughly set so that the high setting was close to the oe low setting, and then it dropped more for access height when parked.
They're adjustable so it's really a matter of how much you want to go given that ride quality suffers the lower you go cause you're giving up play in the suspension.
trdhulk
trdhulk
Got it, thanks!
Did you re-align when you installed the links? Any abnormal tire wear or rubbing? I have 26's
soulsea
Bar
Yes they did an alignment. No rubbing on 24s, can't speak on 26s but I don't see why they would rub as long as you've kept close to the oem geometry. Didn't keep the truck long enough to know about uneven wear, but that shouldn't be a thing if aligned correctly.
Eickybobby5050
