How do I identify what alternator I have in a '04 Yukon Denali
NELLY1947
I have a 2004 Yukon Denali 6.0 and it has an Delphi alternator I believe stock OEM and I can't tell if it's 105 or 135 amp alternator.
How do I identify what size I have so I can get the right alternator I ordered a 105 amp alternator from Amazon it's the AC Delco Gold but I'm not sure if it's going to fit. The alternator is having bearing noises but it works so I was going to replace it because of all the noise the bearing makes.
I want to make sure it fits the the belt size that's already in there cuz the belt is still good
Call a dealer with you S/N it was on the build sheet.
No, none of that. You're just guessing. That would require the tiniest battery and undersized alternator with additional loads that are too much for the stock electrical.
Electrical/THE LOADS, are a pull (what they need, not a push from the battery).
The factory cable from alt to batt + is a fusible link. It is sized for the factory size alternator. If it has too much amperage/resistance then it is designed so that it will burn and break inside the casing, but the case/sheathing will stay intact, in order to prevent a bare wire from connecting off the amp to metal, arcing, and burning your pickup to the ground.
If you're going to upgrade your alt to something larger, you would need to upgrade the charging cable to get the benefit. You would then fuse that cable, and you would want a protected fuse holder.
The cable can be as large as you want. The fuse on the cable, needs to be less than the cable's capability. The point of the fuse is to intentionally create a weak point, that can be controlled, and easily fixed.
I'm mostly pickups, but there are two sizes of alternators, 105 and 130. 105 is a small case, and 130 is the large case. The 130 large case is also, 145, 160, 180, and just about everything else aftermarket. The shape of the two alts are different, and the pulley is in a different spot. The large case uses a serpentine belt that is 3/4" longer than the 105 amp small case. The smaller belt will physically install, on the larger case alt, but will cause more pressure on the alternator, and leads to: hard starting, whining at higher rpm, belt slipping at higher rpm, and poor charging issues. THIS is really why you need to know which alt you have. Personally, you should take the time to find the part number on the belt, and if you wanted, you could always see how to test the output on the alt if you didn't buy it, or own the vehicle since new.
105 came on 99-04, and then in 05 they went from clutch fan to electric fans, and needed a larger 130 amp alt, (might be a little higher on SUVs, the 3 digit K code in the glove box should be your alt size). If you are having bearing noises from the alt, someone may have previously upgraded the alt and not the belt. Replacing the belt to the correct size might solve your problem and be cheaper.
Unless you have aftermarket amps for subs, or have larger draw items in your vehicle like a fridge, or a pump, there's almost no other reason to need a larger alt than factory. If you're not getting voltage drops, then you have all you need.
well I am speaking in regards to a system being under a load, my 2012 came stock with a 160a alternator, I have upgraded it to a 250a and loaded the system to a confirmed 240amp load with a dc clamp meter, so under that load with a 160a alternator I would have experienced system degradation, such as electrical spikes, light dimming, etc.
so while my statement is "speculation" it is based on reality, it may not be something you could see with your eyes but would show on a scope/meter, no "guessing" involved.
it's all based on the load on the alternator
justirv
Thanks Adriver, great, detailed, explanation.
adriver
2005 started charging based on need, as opposed to 2004 and older which had a constant charge. You wouldn't lose anything if your alt and battery combined could handle the draw.
The alt is going to feed the power needed on a 05+, but beyond that your battery is a storage bank, that can still supply for the demand. If you have a 240 amp draw and a 160 amp alt (assuming you are at a high enough rpm for full output), then your battery only needs to be able to supply for the additional 80 amp draw.
The alternator recharges the battery. When the load is less than the alt's supply, you are recharging the battery (If it has dropped). If you have a max 300 amp draw on your stereo, that's going to be when the bass is hitting hard, and the subs are receiving full power. Between those bass hits, you are recharging the battery. You could have a 300 amp draw on your stereo, (another 100amp draw for the vehicle at full use, which would be: efans, ac, headlights, taillights, turns, ECU, fuel injection, brake lights, dash lights), and if your electrical can handle the instant draw (which is why we do the big 3), then you wouldn't notice a voltage drop, unless you are substantially underpowered. If your draw is 60-150 amps more than your alt, then your battery is going to supply the rest. With a 300 amp system, and a 100 amp vehicle, (depending on the music), you could have a 250-320 amp alt, and never notice a voltage drop.
T
talkyukon
I know you already answered your own question, but:
Look in your glovebox at the SPID RPO sticker.
KG4, KG5 150 AMP Alternator
KW8 155 AMP Alternator
KW1 160 AMP Alternator
KW7 170 AMP Alternator
I looked for the sticker and only saw one sticker with 3 digit codes in a square with nothing referencing SPID RPO
I have a picture of my alternator if any one can Identify it by picture.
It does not have the black spacer in between like said in a post previously
It does not have the black spacer in between like said in a post previouslyView attachment 439545
The black spacer is there, it's just dirty gray. It's the red marked area between the two lighter halves of the alternator case in the pic below. By the RPO code it's a 145A alternator.
T
talkyukon
Thanks
Where do you see the RPO code I've been trying to see it the whole time it's good that you identified it for me and confirmed that it's a 145.
Yeah the bearings are squealing really loud on on my alternator when I drive but the alternator works great so I'm just going to change it with a 145 next week when I get the part
justirv
Thanks
OP, was that your picture of the RPO Codes? That label is located inside the glovebox, on the inside of the door. On the picture posted, one can see KG3 in the middle, = to 145A
justirv
T
talkyukon
ooh I see it now thanks for showing me that!!!
Well, it turns out I was wrong, The squeeling got louder and now I can pin point it right to the power steering pump below the alternator.
I'm going to have to send the alternator back and have the power steering pump replaced
One of your RPO codes is JH2, which is hydroboost assist for the brakes (it also list Y91 - Luxury Edition). This system is different from the vacuum assist, and the PS pump is different for the hydroboost system.
If you do the work yourself, be sure to get the correct pump. If your mechanic does the work, he'll figure it out if he's anywhere familiar with these SUVs.
have you ever flushed the power steering fluid? could just be burnt/low fluid I do mine annually as it gets toast just like brake fluid. there is also conditioner you can add while flushing it out, might be worth a try. the fluid is mostly mineral oil which slowly starts to oxidize above 165d
new power steering fluid and brake fluid are both pretty clear looking, not black/darker like motor oil
Escalade2007
