Infotainment Issues a Plenty
UsualSuspect
SoCal
Sine the Y171 update, my wife noticed a few issues with the infotainment system. It looses 4G signal on and off, the Sirius XM audio cuts out, Car Play doesn’t connect automatically like it use to. It isn’t just her phone, mine doesn’t connect either, has something to do with the WiFi, it doesn’t connect automatically, I have to manually cycle the infotainment WiFi.
I was going to have the Y172 update done, then yesterday out of the blue, she gets in, starts it, all the radio station presets are gone, the 2 driver seat presets are set back to factory, and when CarPlay finally connects, it’s like someone hit the magnifier and enlarged the CarPlay infotainment screen. Mechanic looks at it, no codes, battery tests good, he said take it in and get the updates done.
Wife drives it home, sets everything back up. This morning she gets in it, all is well. She is running some errands, parked for maybe 10 minutes, gets in, and everything is reset again. She isn’t happy. Looks like a trip to the stealer for the updates, “Failed Brake Fluid Level Detection”, “Serial Gateway Module and Radio”, and the Y172 update. Hopefully that will either resolve the issue, or brick the infotainment so they have to replace it.
Missing the days of the simplistic pull the station button out, push back in to set it.
U
UsualSuspect
SoCal
Wife gets in the car this morning, starts it, all the stations were there, the seat button programming was back, neither of us did anything, no OTA updates. The stealer said Y172 should fix the CarPlay, 4G, and a few other nuances.
I told him they said the Y171 update would fix the lane departure issue, but it has created more issues, and didn't fix the lane departure. The lane departure either thinks it is always in the correct lane, or it shows no lines. It never alerts or signals, no vibrate, no beeps, no trying to gently steer it back in place. The stealer called this afternoon, apparently the Tech Center has a fix they want to upload for the lane departure. Stealer said it's a one off, he has an Escalade with the same issue. I asked if it fixed the Escalade, short answer is GM updates are VIN specific, and as far as he knows, they only want it applied to ours. Tells me I am the tester. I wonder if the fix is a guess, or if they tested it. In order for the lane departure to be updated, stealer needs the car for a day to apply Y172, the recall fixes, then he has to call the Tech Center and have them release the lane departure fix. Odd thing with the lane departure, it has to be working, but not displaying the true status, Super Cruise still works like it always did, hasn't missed a beat.
BacDoc
Vero Beach Florida
If this is about the “Data Gateway Module” recall?
I had my 2024 Tahoe in for that and it took hours and way longer than I expected. So far I haven’t had any issues but did have to re sign in for some apps. Also I did notice some weird stuff happening when I approached the locked truck with fob on me - some lights going on but I didn’t notice this before, maybe it did but it seems new.
tom3
Wow. All this would give me nightmares if I spent $80k (more?) on a vehicle that I intended to keep for the long run.
U
UsualSuspect
SoCal
It is a bit unnerving, but all the manufacturers have issues, none of them are exempt, basically, pick your poison. The updates were done this morning, plus the additional lane departure fix, and all is working as it should once again. The lane departure hasn't worked in so long I have to get used to it again.
ZKWBQD
I'll give you one little tip. If you ever do get things sort of resolved. Do not do any more updates.
U
UsualSuspect
SoCal
Unfortunately I didn't have any done until there was a problem. Still working through the lane departure. To pay $80k plus for a vehicle, then never update it under warranty is not sound advice, it needs to be dealt with under warranty, do after warranty and it's on your dime, not theirs.
NwtnLkeTheCookie
All of my issues came from this recall. Bluetooth calls now sound static- and are super quiet. Got a new radio installed last friday. NO LUCK. They said ther is a bulletin out for it but no solution in sight!
BacDoc
Vero Beach Florida
Wow, that sucks!
Fortunately I haven’t had any audio quality issues. It doesn’t seem to cause any issues besides the fact I had to reconnect via bluetooth on my phone and sign in to google maps.
Otherwise I haven’t had any problems.
The biggest deal for me was the time it required. I was told about an hour and a half - I got a ride home and came back 3 hours later and still had to wait over 30 minutes. My dealership is usually pretty good with the time frame they give me but this “over the air update” took over 3 hours
navyseal334
Is the update everyone's complaining about the most recent one?
Just got an email from Chevy saying my 2023 Suburban requires an update and I have to take it to the dealership...
Fast_AT4
RWM +1
SW Florida
I had an issue the other day that the radio was playing and didnt turn off when I switched over to Android Auto to listen to Pandora. Disconnected Bluetooth and still present. Turned the AT4 off at a red light and problem resolved. #Odd
U
UsualSuspect
SoCal
The one that caused the issue for me was Y171, the latest is Y172, and some also have a recall on an update for a module. .
Fast_AT4
RWM +1
SW Florida
To be honest, I do not recall seeing any notifications about an update in a long time. They used to popup when they were pushed about needing to be installed/applied.
WalleyeMikeIII
Sunny and Snowy Minnesota
WalleyeMikeIII
Do you notice anything different or is it all behind the scenes updates?
No…but I already had Y172 on my radio.
So the serial data gateway module update just took care of staying powered up after the update…you would notice no more battery drain, but not everyone had this issue.
The Y172 update took care of a few annoying bugs, and comes along for the ride on this one…
johnsonwillie199
