Climate Control Hot or Cold
diezelraccoon
I’ve posted about this before but still have not been able to figure it out the issue.
I have an 03 Chevy Tahoe with the dual knob climate control. When I got it the factory unit dials were not working properly so I purchased a Dorman replacement unit. I can use the dials but most of the time if I turn it up to 89 it stays ok max cold, but once it goes on 90 then it gets hot. A few times it has adjusted to other temperatures but not accurate temperature.
I read about how the air aspirator above the driver can cause this issue. I knew it was going bad because it was making a loud whining sound so I replaced it but it still has not fixed the issue with adjusting the temperature.
At this point I’m at a loss at what is causing the issue. If anyone has any ideas on what the issue is I would appreciate it.
GMT800 2005 Tahoe Z71
Navy Supporting Member
So, "when you got it was not working properly". Then you installed a Dorman unit. It has the listed problems. Are these the same problems as before the Dorman unit or is the Dorman unit problems all new?
D
diezelraccoon
The factory unit was not working properly. The dials were not working properly so I can’t say if this issue existed with the factory unit because the dials didn’t adjust temperate properly.
vsaravia
