Disable TPMS?
XLDenali11
First time posting on here. Sorry in advance if this has been answered. I recently got new wheels and tires for my 2011 GMC Yukon XL Denali and did not swap the the tire pressure sensors as I never look at it and frequently check tire pressure. Is there a way to disable the TPMS light on the dash from coming on or if anyone can point me to a thread answering this question, I would greatly appreciate it.
strutaeng
Dallas, Texas
Not that I'm aware of, unfortunately. I believe the system is tied to the BCM IIRC.
I had the idea of simply having a air-charged steel pipe with the 4 sensors programmed to the vehicle in the trunk or glovebox. If one of them failed, simply replace, reprogram and recharge the pipe. But in the end, I simply bought the Autel TS508(?) that came with 8 sensors and had 2 of my fronts replaced at my local tire shop. Shop charged me $20 and replaced them in like 20 minutes. Reprogramming was also a breeze.
Sorry, that's all I got.
it can be turned off with 3rd party devices, federal requirement so gm will not do it in any case
intheburbs
SE MI
Kind of wondering why you'd want to disable it...TPMS has prevented me from shredding a tire several times. Have gotten a low pressure alert, see the pressure dropping, pull over before the tire's flat and gets trashed.
petethepug
Michael
SoCal
You won’t know you’ve got a flat until the rim has cut a nice slice out of your sidewall. If you have nice tires, it’s the difference between a $35 patch and a $250 mount, balance & tire.
Us AWD folks have to deal with wear tolerances at a certain point so buying one new tire and three tires with maybe not too much meat left will spin our diffs and make us spend more $.
2nd on the BTdieselworks module though. Being able to view, read and / or clear codes in the dash like a factory option is priceless. Same device allow TPMS parameters to be custom changed or turned off.
BadDaddy2003
