Odd problem, rear glass will open when opening tailgate
frk810
Hi guys, git a 2012 yukon xl denali with an odd problem, when opening the tailgate, the glass part will open by itself when tailgate is halfway up. I tried to search online but found nothing related to this issue, is there a setting somewhere to disable this?
Geotrash
Dave
Richmond, VA
That's a new one on me and I've been here a while...
j91z28d1
I can see where that would be very annoying.
I got nothing, but maybe pull a fuse or something to disable it.
Welcome to the Forum from NH.
Pics of the truck, please.
You are already receiving responses and some suggestions for troubleshooting from the knowledgeable folks on this Forum.
mikez71
Could the liftglass switch be broken, where the change in angle makes contact?
Wiring chafed near the hinge area and grounding under movement? (pink wire)
F
frk810
i have not checked the wire, the switch itself for the glass is new, ill try to check the mentioned pink wire
schafer98
