Bigbirney
- Joined
- Jul 23, 2018
- Posts
- 12
- Reaction score
- 4
AC Delco or MOOG? Anyone have experience with either for aftermarket. Similarly priced.
Thanks!
Thanks!
Thanks!
Looks like I'm going to be in need of ball joints on my suburban shortly. Any specific vendor that's recommended for the MOOG units? I see two different lengths listed on Rockauto, are they both compatible?
Ball joints are different depending on whether you have steel or aluminum lower control arms.
Aluminum control arms are thicker and require a thicker ball joint to seat properly.
It's not a hard job at all. Just make sure when you tighten up the control arm to frame bolts/nuts that you have the suspension pre-loaded to ride height.
Also, if you're doing the upper, make sure to mark or take note of where the cam bolts are before starting so that you can get the alignment set back to where it was before. Still good to get it checked professionally after, but making a mark will get you pretty close where it's not super critical.
... ball joint boots and studs had plastic shields, shiny black paint and the bare metal inside the holes and on the edges of the bushing bosses is clean and shiny with no rust. I was pleasantly surprised to see the ball joints have Zerk fittings. The plastic they're wrapped in has a sticker with "EXCK620888" (lower left arm) and "EXCK620889" (lower right arm). Searching those numbers leads me to believe they are Moog CK-series arms...
Grease Zerks!
So, to answer the "MOOG or ACDelco?" debate: In this case, it doesn't matter. These arms are the MOOG CK series, provided to ACDelco as their Professional line and manufactured by Shih Hsiang Auto Parts Co., Ltd.
Generally speaking, the aluminum lower control arms usually came on the AWD models in an effort to save weight. In the big picture, how much are we truly talking, a few lbs?
So, that said, if you're shooting for replacing the entire lower control arm as a unit, I don't see any benefit to going with the aluminum over the steel as the aluminum ones are usually more expensive.
Which one your vehicle currently has would really only come into play if you were opting for just replacing the ball joints as the steel vs aluminum arms take a different ball joint.
It's pretty easy to tell just by looking at them. The aluminum ones will be a lot lighter in color.
Did you ever find this answer?Does anybody know if the strut mounting tabs are thicker on the aluminum arms?
