My car is throwing code P1682
Rizaki
I ran a remote wire to a relay in the fusebox(RUN/CRNK) for my subwoofers and everything worked fine and sounded good. I turned truck off and went to sleep but when i tried to go to work in the am
Everything in my car was working perfect before i installed the remote wire
No starter click
No crank
No start
The relay i hooked up too is not blown
I have checked every single fuse and relay in the box and nothing is blown and everything electrical seems to work just fine
All my electronics come on when i turn the key
I disconnected the remote wire and the power wire from my sound system so that its not interfering with anything anymore
My battery is not dead
Throwing code P1862 DRIVER 5 LINE 2
I replaced the ignition switch and it still wont start
The (ENG) fuse is pulling 11.63 steady
The (ECM-IGN) fuse is pulling 11.63 steady
2008 yukon xl 5.3/4l60/4wd
Welcome to the Forum from NH.
Pics of the truck, please.
I cannot personally assist you with your issue, but other members of this Forum much more knowledgeable than me in this area will chime in.
I
No starter click
No crank
No start
I don't even show that code for my 2009 or 2013. But what I can see is your dead battery at 11.6 volts.
When a battery's state of charge is below 65% after sitting overnight, it's time for replacement.
I
Most probable. However, if either of the main (pos, neg) battery cables is bad, that could cause a voltage drop between the battery and the fusebox.
1948Buickroadie
