2016 Yukon XL repairs for 100k miles
WELCOME to one the most helpful and informational places you could possibly find for the Yukon…..
What I’m hearing is “Let me get you in touch with our sales manager” type scenario…. DON’T BITE……
FIRST AND FOREMOST…Do you plan on keeping it for a while? If yes… see below… If no…. “ Let me get you in touch with our sales manager.”
I’ll say that’s absurdly high. Absolutely get a second opinion and have “leaks” verified. What are they defining as a “leak”? Unless you are dumping fluid and leaving drips and puddles in your driveway , I’ll say some seepage is ok and not cause for immediate concern. On that list, should there be actual leaks, I would hit the the potential “BIG ticket” items first meaning they have the potential to cause bigger issues.
IF (doubtful) your second opinion agrees with the stealership……….
I would address the cooling system issue first. Water pump, and surge tank. I would also replace the thermostat under an abundance of caution. Water pump can be kinda spendy…
Next I would look into the oil system issues and have them verified and fixed.
IF the rear diff is ACTUALLY leaking get that done as well.
The transmissions in these things are notorious for issues and I would do the 20 gallon flush and install a thermal bypass (super simple at home with needle nose pliers, 2 wrenches and a towel). The flush at the dealer I believe runs around $300 or so.
Spark plugs….unless you are having drive ability issues. That’s a no and save $500.
Struts.. go Aftermarket and save an ACTUAL ton of money. I replaced all four of mine for less than what the stealer wanted for just the front.
Brake fluid flush….. meh I do it every now and then but it not HIGH on my priority list.
Hopefully this helps.
20 gallons
:yaoface2: (WTF)...........
Coveman
On my 2013 I did a few of those items around 100k miles. I do my own work so parts only:
Spark plugs $30
Transmission service $50 for fluid, $25 for filter
Oil cooler lines $101 (this is a time consuming job for 4x4s)
Brake fluid flush $25 (this should normally happen in conjunction with replacing brakes)
None of the other items have been worked on my truck before. IF your water pump is leaking from the weep hole it definitely needs attention, and the expansion tank cannot have cracks as it is integral to the cooling system so those would be areas to address.
I’ve heard similar stories from both dealerships and auto chains, hopefully you can find an independent that is trustworthy and can point out these problems on your truck for you to see.
Good luck and welcome to the forum!
ViperOne
Hello all! I’m the original owner of a 2016 Yukon XL Denali. It just flipped 100k. I took it into our dealer because the tire pressure sensor needed to be reset. While there I asked them to do a once over on it and give me an estimate on anything that needed work. Here is the list. The estimate is like $8k+….. soooo…. before I have a bunch of work done, I thought I’d ask if anyone has had these done on their similar year Yukon. Or if anyone has other advice. Given there is so much and it’s so much money I’m doing a little homework. We’ve had very few problems with this vehicle. I take it in for the usual maintenance at a local place near me and am always on time with oil changes, tire rotations, etc.
Does this all sound reasonable for a vehicle of this age and mileage?
- New spark plugs
- Front struts are apparently shot and need to be replaced (didn’t notice but maybe I don’t know what I’m supposed to be noticing with the ride)
- Surge tank leak
- Oil pan leak
- Oil lines leaking
- Rear differential leak
- Water pump leak
- Brake fluid change
- Transmission service
My opinion…you ask the dealer to look it over and give you an estimate. Sounds like you got what you ask for, they went looking for any sign of a potential issue regardless of severity. You get to pick what gets done and when and by whom. 8k is a lot of money and like others have stated I would shop around. I’m not pro dealer but I do like the idea of techs being familiar with my make and model. Like everyone else I think dealership service is extremely high and yes I’ve had bad service at both dealerships and auto repair facilities. I also do my own repairs when possible because I trust my work.
clogan2
First, you should refer to your owner's manual listing of scheduled services needed.
Depending on your service history, you certainly need the tranny service, spark plugs, and brake fluid change. These are scheduled maintenance items listed in your owner's manual. You also likely need a gear oil change for the transfer case, assuming you have 4wd. You may also need an engine air filter, and a cabin air filter. There may be other items listed in your owner's manual that do not immediately come to mind.
Secondly, look at your garage floor. If you see oil and/or coolant spots, that's a clear confirmation that the leaking items need attention.
It always pays to get a second opinion/estimate, but remember the old saying: "Never ask a barber if you need a haircut ".
dark_knight
Why would he be joking? Who better to look over a vehicle than a place that works on basically nothing but that vehicle?
Don't take it personal man. You might be one of the good ones but there are plenty that are not. My parents took a car to a dealership because the ac pump compressor was going bad and bogging down the engine. I knew what the problem was but they trusted that dealer. After the 8k estimate for basically a new engine, I told my dad to cut the ac belt and drive it home. It never ran better. that's just one of many stories.
04pillows_artisan
- New spark plugs
- Surge tank leak
- Oil pan leak
- Oil lines leaking
- Water pump leak
Spark plugs 120k
I did all the other stuff at 40k. no water pump. did rear diff, brake fluid, trans @40k , transfer case.
04pillows_artisan
- New spark plugs
- Surge tank leak
- Oil pan leak
- Oil lines leaking
- Water pump leak
No spark plugs 120k
front struts, maybe?
Oil pan leaks should not happen.
Change rear diff. I changed mine @40K
transmission service@ 40k
Brake flush with new pads.
You might need a water pump at 100k plus timing chain.
blackelky
I agree with everyone here. I typically do spark plugs and all fluid changes when my vehicles hit 100k. Tranmission service 60ishk miles. But most fluids are easy if you follow youtube directions.
buckwild27
EMT/First Responder Firefighter
Ohio
a technician (ASE) certified, can still be inept no matter who they work for............ the industry has a fairly high turnover rate
I could probably go pass the test right now without even studying and I am part idiot
Lol, I passed the ASE cert test for diesel mechanic on about an hr of sleep and pretty sure still hammered from the jungle juice party the night before. You for sure could past no problem.
91RS
GA
No spark plugs 120k
Oil pan leaks should not happen but you should change a water pump and timing chain just because at 100k?
mamalisa08
mamalisa08
- New spark plugs
- Surge tank leak
- Oil pan leak
- Oil lines leaking
- Water pump leak
Hello all! Here is an update because some of you asked and I need more advice. LOL. I went to the 2nd, locally owned place. Here's what they said:
- Coolant hose at bottom of tank is leaking and hose is soft; recommend immediate replacement.
- Rear air shocks are damaged and compressor is disconnected from them (Note: my vehicle was rear ended while parked a month after we bought it in 2016. There was $20k worth of work done to it and I wonder if this was never properly fixed during those repairs).
- Also saying front struts are leaking (again I don't notice anything with the ride; my dad says they're trying to make $$$ off me).
- Rear axle has oil seeping
- No signs of water pump leak
Re: shocks and struts: the guy suggested we consider a delete kit where we remove the air ride system and put in "standard" shocks and struts. Has anyone done this and how did it go? He is saying it's a much more cost effective move and will save us more money in the future. Thoughts on a delete kit?
Right now I'm leaning toward having them fix the coolant hose and dealing with the disconnected compressor. How important are the other leaks? Nothing drips onto the driveway at this time.
Finally - I do not have plans to replace this vehicle any time soon. I love it and try to take care of it. We have 4 kids at home and need a large vehicle. No interest in spending upwards of $100k to replace it and my husband is going to be upgrading his own truck soon so we need to spend $ on that, because we pay cash for our vehicles.
Thanks for your help!
mamalisa08
mamalisa08
The dealer gave you good advice on a red flag that it’s time for the major 100k service interval.
They also gave you the current market rate for dealership labor. Just WOW! That’s a little higher than our last Denali purchased in 06 and the second one in 14. We’re on the third iteration now and in an Escalade. Cracked surge tank / coolant reservoir will cause overheating and potentially loss of a perfect motor. Fix that asap!
Is your Denali 4WD or 2WD?
4WD
Geotrash
Dave
Richmond, VA
Sounds like a solid plan. Coolant recovery tank leaks are common in that spot. Your hypothesis on the rear air shocks sounds plausible.
Post a pic of the rear end "seep" and we can advise from there.
91RS
GA
Deleting the Mag Ride isn’t necessarily a bad idea since these ride so bad with it but quality suspension parts aren’t cheap. Most places that recommend it use the cheapest junk and then it doesn’t ride nice. I would either recommend buy new OEM shocks with the correct part number from Rock Auto (the cheapest place to buy them but don’t use their catalog to look them up) or if you do decide to delete it, check out this web site:
I have never used them, but I like what I see. The kits they have put together look nice. I really want to try the Fox coilovers but I don’t want to lose my rear air suspension.
One thing to note, OEM GM suspension components have a lifetime warranty so if you buy the OEM shocks, you won’t have to buy them again.
jdwood1111
Your plan sounds good. As others have recommended, please send pictures of your rear because if it has been "leaking" for a while you may want to have that changed as it could be a little low on oil. I would keep the stock suspension and replace with OEM from rockauto or Arnott as others on here have recommended as well. This way, the air suspension stays in which is good if your going to be loading up a decent amount. Just FYI, they are now around $270 or so each I believe but haven't looked them up in a bit.
Definitely do the hoses and such. I actually just changed out all my hoses and heater tees 2 weeks ago! If they are doing the hoses, I would ask them to look at those two heater hose tees at the firewall!
petethepug
Michael
SoCal
4 kids. Why would a guy want you to add resistors made for home lighting projects to fool your stability system into thinking a potential rollover isn’t really happening so it can avoid it? That kit he’s referring to lowers resale and potentially makes it unable to sell or trade to a dealer. Why would they want to accept liability of a bypassed safety system?
Surge tank leak
- Oil pan leak
- Oil lines leaking
- Water pump leak
Do the water pump & trans service ASAP. Also replace the carbon canister that’s know to pollute your entire fuel system when it fails ($125). Some labor & maint jobs on these 4WD / AWD trucks shakes hands.
The trans is removed for the 100k major service. It’s a $6-$8k part to replace if not maintained. Do the service! When the trans is out:
* the oil pan job goes from $4h to $1h.
* motor mounts from $9h to $4h.
* o ring on oil pump from $5h to $50 with doing the oil pan.
* front diff mounts from $5h to $2h
* Rear main seal $9h to $1h
Same goes for whatever oil lines are being referred to. Do *stuff ASAP during 100k major trans service. Missing it means those higher labor & repair items eat you alive. Properly addressed means another 100k trouble free miles.
1948Buickroadie
