GM 6L80 Transmission Information Thread
ilikemikes
Austin, TX
Amazing thread Nick! Bought a reman GM trans about 75k miles ago 09/2018. Have not done any maintenance on it. Yesterday started getting about a 2 sec delay when I shift into Drive. Thoughts please? About to go on vacay tomorrow. Could a filter and fluid resolve this issue? Thanks in advance.
NickTransmissions
NickTransmissions
Sin City
The transmission bench
Thanks, Mike - appreciate the kind words!
I'd put a few more drive cycles to see if the condition persists...If so, drop the pan and inspect the bottom, that will be the easiest/fastest way to determine if the transmission is beginning to fail in some way as you'll see dark, burnt clutch material and/or sand-like material that could be either bronze/gold or silver in color...If anything like that is observed, put the pan back on with a couple bolts and yank it for overhaul and rent a car or SUV for your trip (If in doubt about your Tahoe at all, I'd suggest grabbing a rental).
Also inspect the filter neck. These have been known to crack from time to time, that can also cause everything from delayed engagements to no movement.
Is reverse also delayed by a sec or two or is it normal?
NickTransmissions
NickTransmissions
Sin City
Thanks for the quick response. Reverse is normal.
Yea, I'd drive it a few more times locally, pay attn to the amount of time for each delayed engagement into drive, especially when fluid has warmed to normal operating temp. If there's a difference, that tells me soft parts are beginning to wear; if it's the same cold or hot, could be forward piston beginning to crack (common) or sprag beginning to roll over...Could also be #1 check ball beginning to get stuck in the plate or a TEHCM issue w/either one of the shift solenoids, the 1-2-3-4 clutch pressure control solenoid or pressure switches not communicating range position to the PCM quickly enough upon shift into Drive.
ilikemikes
Austin, TX
Nick, I called the top rated transmission shop here in Austin and this is the quote I got. They wanted me to get a diagnosis first but I explained the pause going into Drive is getting a longer and probably won't last much longer.
Thoughts on this? They are calling this service a full rebuild. They are not doing teardowns to fix specific parts. I don't really like the warranty. I think the reman I bought from GM came with 3yr/100k warranty.
2011 Tahoe 5.3 All stock Tow boat 6L80 Stg 1 $4000 plus tax, complete job Stg 1.5 rated 500HP $4400 plus tax, complete job *includes billet torque converter* 40k cooler would be recommended $350 installed Warranty 18months/18k miles Require 50% deposit
Thanks again for your input.
NickTransmissions
NickTransmissions
Sin City
The price sounds about right though I'd want to confirm you're getting a new TEHCM from GM in that price. Otherwise, it may be a bit high. The warranty isn't too bad at all for an independent shop...You have to remember, General Motors is a multi-billion dollar company, the source company for all of these transmissions and has warranty reserve capital that would blow your mind so if an independent repair shop (a microscopic entity by comparison) is able to provide a 1-2 year warranty, that's very good provided they stand behind it. Another positive sign is that they don't do flat rate/'fix-it' type work and I'm the same way with these units...If I'm getting my grubby mitts on it, it's coming all apart and getting overhauled per page one of the thread (at minimum).
If possible, I'd want to know what they will be doing to the unit and what parts will be installed...Bump that up against the list of parts on page 1 to see if you have apples to apples. I'd also be curious as to what friction module they would be using...Given the name of the build, perhaps either Raybestos Stage One frictions, GPZ or Alto HE or Reds? Billet torque converter is a nice upgrade, esp for towing/hauling in the summer time as that's when heat will cause conventional tc covers to flex/warp if stressed enough...
ilikemikes
Austin, TX
Just getting back to this Nick, thank you sir! I will ask for some specifics. Was just talking to my neighbor (ex-mechanic now engineer), he thinks the Billet torque converter is over doing my stock engine and for the amount of towing I do. I tow my bass boat once a week 30 to 100 miles. Its maybe 3500lbs. The Tahoe is currently a little sluggish while towing the boat and would like some pep. Thoughts? Thanks again.
S33k3r
Dallas, Texas
Money says you are running a 3.42 gear ratio. What size tires are you running? I'm thinking smaller tires or a larger ratio, like 3.73.
S33k3r
Dallas, Texas
With taller tires you are also going to want taller (numerically) gears. Otherwise you are losing mechanical advantage. It's great for highway gas mileage, but not so great for quick acceleration. There's an article in my signature with a chart.
ilikemikes
Austin, TX
Got some details Nick...
✅ 6L80 stage 1 2800.00 18/18 warranty ✅ Best bang for your buck in Texas! : ✅ new Florida brand carbon clutch torque converter ✅ proprietary heavy duty 4-5-6 drum set up with borg warmer friction plates and thick steels, (only lathe machining the parts can achieve this) ✅ modified boost system for quick pressure rise ✅new oversized pressure pressure regulator valve ✅Performance built valve body with torque converter valve update, end plugs, AFL valve update, and vacuum tested for tolerances ✅lathe machined like new pump stator ✅ Case is sand blasted and coated with automotive grade paint and clear ✅ cooler flow pump modifications to keep stock or 40k coolers at max efficiency! ✅ OEM dealer , gasket, o’ring, and screen kit for TEHCM ✅ TEHCM fully tested and programmed to your tire size and gear ratio , also includes new aftermarket software for longer torque converter durability and zero shudder issues! ✅ zero snake oil parts ✅ firm shift tune available upon request at no extra charge, otherwise transmission will shift smooth. ☑️18,000 mile 18 month warranty on entire transmission including TEHCM/computer, with invoice and serial # DECAL unit built by diesel Master ASE certified, ATRA instructor Pepe Torres building performace unit since 2005! beware: all of our units include a serial # with flag and logo for identification Beware of copy cats PRO installation special is 1200.00 Includes HOT FLUSH machine that flushes transmission cooler/s, full synthetic fluid fill, computer adapts reset and road test
Sparksalot
Bastrop County, Texas
Which shop is this?
NickTransmissions
NickTransmissions
Sin City
ilikemikes
Austin, TX
These folks?
$2800 is for a complete overhaul, torque converter plus $1200 r/r so 4$k...not bad if so..
Yes sir. Aus-Tex Transmission. They have great reviews and seem reputable.
Am I overdoing it by getting the Billet torque converter?
NickTransmissions
NickTransmissions
Sin City
It's up to you on the billet converter cover; I typically only do them on HP or HD builds but sometimes the customer wants one, regardless.
YukCCR
I hope this is the correct place to ask this question, if not I apologize. I just had my 6l80 transmission replaced on my 2007 Yukon Denali with 147K miles by the chevy dealer Bill Roberts Bolivar MO, for $5600. When I got it back yesterday, I tried the manual shift mode and it does not do anything. I called the service advisor and he said that had nothing to do with the transmission, that it would be a problem in the buttons on the column. So, if I take it back it will be more money. Should I try to troubleshoot myself using the videos and 14 pages of posts on this forum, or should this have been part of the replacement?
YukCCR
To clarify the history - the shifting problems began around the first of this year, and the manual shift mode stopped working at the same time. The two shops I took it to prior to the dealer both said it need a transmission rebuild or replace. They did not say that the manual shift mode, which I noted in my complaints, was a separate issue that would not be solved by the transmission replacement. I went with the dealer trans because of the warranty.
began
1948Buickroadie
