Afm
Magallon0820
So, I have a 2016 tahoe with 130k on it got it at 120. I have read about the afm delete and I do not want to pay for a new tranmission, so the question was what reccemndation do ya'll have on which one to get, I am not trying to pay thousands I found some on Amazon for cheap but also understand the you get what you pay for, so which cheap ones yall recommend?
K2 Kaiju
The Depths
AFM has nothing to do with tranny. As for tuner, get a used diablosport off ebay. I picked up one a few years ago for $250 or so, and I have used it on my last 2 rigs. You can tune, change tire size & pedal sensitivity, and turn off AFM or speed limiter plus custom tunes. Best bang for buck...
Marky Dissod
You can tune, change tire size & pedal sensitivity, and turn off AFM or speed limiter plus custom tunes. Best bang for buck ...
Engine Half@$$ does have something to do with the transmission ... tuning.
Torque converter clutch slip in cars with Engine Half@$$ is higher than in 2500-&-up trucks
that lack Engine Half@$$.
So when your diablosport disables Engine Half@$$, it may not reduce the TCC slip.
So even if your engine is always a V8, the TCC will still slip and wear out eventually,
which will eventually take out the 6L80.
A full tune from a reputable human being will permanently disable Engine Half@$$,
AND also retune the 6L80 to correct the TCC slip, among many other things that can be
custom suited to your tastes, including tire size & pedal sensitivity.
tom3
Son had disabled his AFM at 85k miles, trans went out at just over 100k. Could have been just ready to go but still had a complete transmission fail due to the torque converter slipping as designed. Transmission shop had the equipment to re-program all that nonsense out and it drives like it should now. I'd highly recommend a full tune for this. If I didn't have the GMEPP warranty I'd sure do it quick.
BattleTank
Senior Member
Why do I see no reference to TCC slip on HPTuners forums when it comes to AFM disable?
B-train
You could also put in a RANGE Device that disables AFM. I used one for 110k miles before I got HP TUNERS and it worked great.
I'll let it go for a good price. Anyone interested PM me.
Marky Dissod
You could also put in a RANGE Device that disables Engine Half@$$. I used one for 110k miles before I got HP TUNERS and it worked great.
They work very well for disabling Engine Half@$$.
However they cannot / do not fix the GM OE TCC slip percentage.
B-train
So I could in theory copy the V4 table to the V8 side and be done?
I would assume so. But, if you have AFM turned off, it will never go there. It has a different slip map to allow it to stay in V4 longer and probably feel smoother to the driver.
06 Taco
I've read every thread that I could find for the last couple of years and this is the first time that I read that deleting AFM effects your transmission. I've been using a Range Technologies OBDI AFM disabler on my 2015 Yukon Denali for about 20,000 miles with no issues. I have the 6.2 with the 8 speed tranny. Am I fixing one issue only to cause another problem?
L8T BURB
Kentucky
My stance is that disabling AFM via tune only or a full mechanical AFM delete will impact the transmission, but in a good way. The engine jumping between V4 and V8 is troublesome for the TCC and transmission in general. Generates more heat and unnecessary friction on the wear parts inside the transmission.
I would recommend a couple things for you.
1. Get a reputable tuner to write a tune for your Yukon that disables AFM. (No need for range device after this)
2. Also have reputable tuner write a tune for the transmission that will fully disable TCC slippage in all gears. In addition, in my 6L80, my tuner only enabled TCC lockup in gears 5/6. With you having the 8-speed, research which gears are ideal for TCC lockup. I assume gears 7/8 but thats a total shot in the dark. Don't take me at my word on that part lol.
3. Get a thermostat bypass for the transmission. In addition to the crappy OEM tuning of the transmission causing it to operate at a higher temperature, the thermostat is also a known culprit to the heat. The factory GM transmission thermostat doesn't open until around 192 degrees and even sometimes will run over the 200 degree mark. For most transmissions that may be fine, but these GM transmissions do not live long under continued use at those temperatures.
For reference, I had an engine and transmission tune written for my 2015 Suburban for $150. This included about 3 different revisions to iron out the very fine details.
Marky Dissod
The engine jumping between V4 & V8 is troublesome for the TCC and transmission in general;
it generates more heat and unnecessary friction on the wear parts inside the transmission.
It's also GM's stance, on two different subjects.
Engine Half@$$ (I've no respect for V4 mode) isn't good for the engine or the transmission.
It trades engine longevity & durability for not enough MpG.
GM tunes the torque converter clutch behavior differently between civilian / 1500 vehicles vs heavier duty vehicles.
GM does not want civilian customers to feel or notice the TCC locking or unlocking,
so 1500 vehicles have the TCC tuned to slip by GM OE.
Heavier-duty vehicles not only avoid Engine Half@$$ (and 'Cylinder Confusion'),
they also do not bother slipping the TCC lockup or release to try to soften or hide it.
A more thorough aftermarket tune (among MANY other things) 'borrows' this heavier-duty TCC behavior,
which increases transmission durability & longevity, especially when combined with ATF servicing.
Disabling Engine Half@$$ is a GREAT IDEA in and of itself; it improves the engine's odds of lasting much longer,
but if this disablement is done with a plug-in, the light-duty TCC slip is left as is.
Although disabling Engine Half@$$ helps the transmission too, it can never help as much as a thorough tune.
Marky Dissod
Separate from Engine Half@$$ / Cylinder Confusion,
torque converter lockup is another tradeoff between MpG vs durability / longevity.
When MpG is the goal AND the risk to the powertrain is lowest - when driving 'gently' -
locking the TCC helps MpG and has little to no negative impact on durability / longevity.
This typically applies to the direct-driven / 1-to-1 gear and the overdriven gears in a transmission.
Marky Dissod
Continuing the above ...
The torque converter clutch's ONLY goal is MpG, specifically, enhancing MpG in the gear you're already in.
The above assumes the goal at the moment is to improve MpG, which is why the 6L80 8L90 & 10L80 are capable of locking the TCC in every gear (except 1st). (Even the 4L60E can lock the TCC in 2nd! - can, but NOT should.)
TCC wear is minimized by (not only) zeroing out what GM considers acceptable TCC slip (in the tune), but
also by tuning it out entirely in the underdriven gears.
6L80 lacks a direct-driven gear, so tuning out TCC lockup in 3rd & 4th costs an MpG or 2, but this buys longevity.
For the 8L90, tune out all TCC lockup in 3rd 4th & 5th - only use the TCC in 6th 7th & 8th.
For the 10L80, tune out all TCC lockup in 3rd 4th 5th & 6th - only use the TCC in 7th 8th 9th & 10th.
(I'm aware that the 10L90 tcm is presently difficult to access for the prpose of aftermarket tuning - just saying.)
TL;DR:
Disabling Engine Half@$$ or Cylinder Confusion helps both engine and transmission last longer.
However, plug-in canned 'tunes' don't go anywhere near as far in terms of benefits to powertrain longevity.
A more thorough tune, either by mail-order, or in person, includes a plethora of other benefits.
Chief among those extra benefits is extending the life of the TCC, and the transmission as a result
Even if this costs a few highway MpG, most people would prefer a vehicle that lasts much longer.
blondie70
A mechanic is writing a transmission tune for me. Will notify when it's ready. Says it's gonna be about $300. I already have AFM disabled. I told him the list of things I wanted that I got from here (as above posts by Marky)
He said these things should prolong the life of the trans.....but.....seems like these transmissions have some kinda death wish or something...ha ha
Mine is working perfectly now at about 199K. Trying to keep it that way.
K2 Kaiju
The Depths
This is also the first time I have seen AFM and transmission failure linked. Seems GM could easily do a recall and fix a huge thorn in their side with a simple flash if this is accurate. I have the 10 speed so I cant tune it with this (or any AFAIK) tuner, but it does tune the the 6L80. I was able to tune the 6 speed in my 18 burb to "firm" shifts. Diablew does custom tunes that can address the pressures for $175. I remember the 4 speed being a steaming pile of dung before AFM was even a thing, and everyone hailed the 6L80 as a godsend for the first 5 years...
Marky Dissod
This is also the first time I have seen Engine Half@$$ and transmission failure linked.
They are linked by a link. If the GM OE TCC slip factor is eliminated, and/or the TCC is upgraded,
the driver and riders may notice the Engine Half@$$ transitions, but the TCC will last MUCH longer.
Limit the use of the TCC to 5th and 6th at very light throttle, and the TCC will last even longer still.
This assumes GM would want 6L80s to last longer.
I remember the 4L60E being a steaming pile of dung before AFM was even a thing ...
4L60Es were designed for MpGs, not durability or longevity. That said,
it was clear back then, that 4L60Es built with 7000lb or heavier 'tow pack' options lasted longer.
and everyone hailed the 6L80 as a godsend for the first 5 years ...
... until the 6L80s' TCCs started wearing out?
Conedaddy
