Farewell lifted Tahoes
Dustin Jackson
It was nice knowing all the good people here but I regret to inform you that I have unlifted my Tahoe.
My setup, while great, wasn’t perfect and with the ball joints in my Rough Country forged upper control arms going out I decided to take this opportunity to remove the lift. I ended up going with some Mevotech TTX control arms the green ones.
The change in front included removing the front 2.5 inch over strut spacer, swapping in the Mevotech control arms, and removing my CV axles since it seems the front diff has developed a problem.
In the rear I removed the 2.5 inch lift block under my springs, removed the rough country shock extension bracket, and swapping factory length rear sway bar end links back in.
I also removed my 1.5 or 1.75 inch wheels spacers on all 4 corners so she lost some of her wide stance look as well.
I am happy that she still looks great at this height and I am looking forward to a slightly more comfortable ride and a suspension that isn’t fighting itself like it was before, the 2.5 inch spacer was too much for the rough country arms to handle and the upper ball joint was binding at full extension.
After
Before
After is better than before. I never saw before but am not a fan of the lifted Tahoes or Yukons. All that does is add more stress to the steering/suspension/frame.
Fully agree.
After
Before
Welcome back to the world of OEM suspensions. Yes, suspension preference/beauty is in the eye of the beholder, OEM suspension design is in the eye of the Design Engineer.
Trey Hardy
After
Before
well maybe you can get back over to the dark side before it’s over with
I feel like some nicer uca would’ve made a difference in your ride or a coil over conversion but I know their pricey that’s why I got my stuff used off marketplace and Craigslist for dirt cheap just gotta wait for the right deal to fall in your lap
It looks good stock though but I’ll definitely miss your lifted look I felt like you had one of the cleaner leveled rigs on here and always thought it looked awesome!
If you decide to go back I can help you out on building a decent system but rough country definitely isn’t it you can piece it together like I did the Silverado with a rc lift fabtech uniball uca and icon coil overs that was a nice ride but stock struts and rc forged arms rode like dogshit
Dustin Jackson
Dustin Jackson
Looks a wee lil bit taller than OE, like it'd still be too tall for many NYC parking garages.
Looks right nice, to me, anyway.
@Marky Dissod I have Moog 81244 springs in the front and 81069 in the rear so it is still probably a bit taller than the average Tahoe but from the angles of the suspension now it looks a lot more comfortable within factory geometry, hopefully it rides a little nicer now.
Dustin Jackson
Dustin Jackson
@Trey Hardy I might go with a lift again eventually, I like the height of 3 inches of lift but there are no kits that address the lower control arm angle for 3 inches.
I have a 94 k1400 that I am going to make into my off road rig I think
Trey Hardy
I believe cognito is about the only company who makes a 4” lift with the crossmember drops it’ll show up as a Silverados but you would just reuse your rear lift items for the back half
That kit with some nice coil overs and uniball uca your Tahoe would be riding better then it does in stock form but again shit is expensive that’s why I do my stuff one piece at a time
For the rear you don’t need trailing arm drops until you get up around 6-8” but a adjustable panhard would be needed to center the rear end
Trey Hardy
If your going to heavily off-road it solid axle swap will be your best bet if not plan to do the full kryptonite suspension on it or else you’ll be changing ball joints and wheel bearings ever couple months we beat the shit out my buddy’s old truck and we were constantly replacing front end parts with his 6” rough country lift but we were using moog parts and I think that’s about the time the moog quality dropped
GMT800 2005 Tahoe Z71
Navy Supporting Member
See......see......"rides a little nicer now"......I rest my case.....
Agreed. As a former owner of a purpose built off road rig, solid axle is the way to go. That K1500 could handle a Dana60 at the front and a FF 14 bolt at the rear.
Dustin Jackson
Dustin Jackson
@Actifenpleinair I think so, it is now lower to the ground the wheels are closer to the body. I suspect I picked up at least 1mpg since I removed the lift and wheel spacers.
Capybarbro
