2012 BellTech lowered LT 4WD return to OE
redfusion
Howdy,
I want to go back to smooth OEM suspension. I've got a 4WD LT so it runs belltech strut drop up front and belltech coil/shock drop in the rear.
Can someone please post the OEM strut/shock/coil part numbers? I see ZW7 listed on my glove box if that helps.
R
redfusion
Well reading up on ZW7 means some sort of auto leveling non electronic suspension. Dont really want that and the OEM coil 22811851 is discontinued anyways. So now just looking for closest thing available that would work in the rear. I dont tow or ever use the 3rd row. Mostly just 2 adults 2 kids. What are my options?
Caddylack
Do you want my PPV springs? 1" lower than stock, but not very low.
As far as the softness of the ride, that's where you want to invest in some good shocks. Maybe Arnott?
Go to GMPartsDirect.com, enter your VIN, go to the Suspension section, and look for the exploded diagram that shows the shocks. You should find what you are looking for along with the correct part number. And, the cost will be significantly cheaper than the local dealer.
You may need to match a second RPO code from your glovebox sticker to zero in on the correct OEM replacements.
R
redfusion
well even with the VIN it is not specific enough and shows too many options. ended up calling them and they gave me the part numbers. But rear coils have been discontinued so looking for the next best setup.
R
redfusion
I'll look into this. Is your 4WD? Do you have a pic?
R
redfusion
PPV would be a step down from Belltech in term of ride quality so no go there.
R
redfusion
Is there any replacement for GM rear coil part 22811851 that mates to the the GM ZW7 rear shock part 22811847?
Caddylack
I don't think that's accurate.
The PPV as a whole rides very harsh, but I would bet against the springs being more firm than Belltech lowering springs.
The PPV struts and the shorter tire height are most of the difference, I think.
That is where the secondary RPO code comes in. You absolutely can identify the correct part, using this method. But, calling the dealer is a easy substitute.
Try Moog for a compatible spring replacement.
Tahoe14
Central Fl
Did you do a search online using that part# to see if there is any new old stock available.
JasonW4141
