3rd row Help 2017
AdamKansasCity
Hi, everyone.
I'm having an issue with the 3rd row 60 side latches not actuating in the up or down position. The up/down drive motor is all that is functioning.
The 40 side operates as it should. While pushing up or down the latch actuator pulls the two cables to unlatch the lock then the drive motor moves the seat to the desired position then latches into place.
It seems that the 60 side could be in an in between state where a position sensor doesn't call to latch or unlatch.
I'm hoping someone here knows remedy for problem.
All resources are welcome.
Thanks
Quote Reply
Report ••
KMeloney
I'm sure someone can help. Just move it to the '15-'21 section (you've put this in the '21+ section). Good luck!
Dh1280
