Reduced Engine Power, an opinion and experience piece!
Eldiablo
My Experience: Reduced engine power, my thoughts and ideas. If you are having this condition, which in effect will affect every loving gm owner of trucks trahoes and gmcs. Im going to list these, they are self descripve in nature.
First Things to check.
!: grounds, check under drivers front fender, bhind engine on both side and battery cables. I dont buy into running wires all over. If it is in good shape has designed not necessary.
2: Check your battery with a good battery checker, if at all questionable replace.
3: Same goes for the alternator, not only check output but check the regulator with a good battery tester.
4: Now you move to the throttle body, check it closley.
5: Now inspect wiring to throttle body connector and inspect all wiring having anything to do with tac module.
6: Fuel system, injectors fuel pump and so on. Get a fuel pressure tester and a long hose and go for a drive.
7: and just for poop and giggles check those coils plugs and wires.
8: Dont be shocked if you replace some parts and they are bad right out of the box. Learn to ohm everything.
If you have not fixed this problem by now, well you need superman mechanic.
I beleive this problem is so vast and it is affecting millions of gm owners, I feel there needs to be litigation on this subject, I hear way to many stories of people spending big money at the stealership and they cant fix the problem. I am worried of the future of this country when it comes to all repairs. No one wants to be a mechanic anymore, and most fathers are not teaching there children any of this becasue they werent taught any of it. I apreciate all your help and friendship. We will speak soon! Good luck. One thing, dont let the fear of all this hype aboutg this problem stear you away from tackling it. It is still all nuts n bolts.
rockola1971
Indiana (formerly IL)
I disagree. Its almost always either a bad/worn TPS, Its associated wire harness (broken wire), Bad TAC module wiring harness (broken wire), Bad TAC module, Bad/worn Foot pedal Pot or ground issue. In that order of most likely fault.
Phillip Bradbury
I’m coming into this conversation in May but have been dealing with it for ten years, 5 mechanics and they just do what computer tells them. The last STEALERSHIP, I love it, said if this $858 solution doesn’t work, there is nothing we can do. Doyou believe that? I called GM, explained all of that, and 2 eeeks later no call. After $6,000 in repairs, utube guy said put a #8 ground wire from -battery post to TAC module post to firewall bolt to alternator bolt, it started and no check light. I will get back to you after I drive it for a while.
Phillip Bradbury
04 Tahoe 5.3LT. Have a rattle sound going over bumps coming from area in front of driver. I cannot find anything loose, and does not rattle when I bounce car when standing still. Mechanics just shrug it off, don’t worry about it. They don’t have to drive it and listen to it all the time. Any ideas?
Peeledpeas
My 2003 Silverado does this but only in the winter and only when it gets really cold for a few weeks. Like about 20 degrees or colder. Always on the freeway and it always goes back to normal after pulling over and shutting off and restarting.
travstick
How is it doing?
ScottS-Michigan
