DontTaseMeBro
- Joined
- Feb 9, 2024
- Posts
- 415
- Reaction score
- 334
2022 Yukon. Fuel door won’t release. I suspect the plunger fell off. How do I open it? I tried a plastic trim pry tool to no avail.
It’s not. So the lock actuator on the vehicle side doesn’t appear to click in. I pushed all the way in on it with a screwdriver and it springs back. Is that normal? If not, do I have to replace the whole housing?Is it still under warranty, if so I would take it to the Dealer.
What did you do to repair the missing/broken part?It’s not. So the lock actuator on the vehicle side doesn’t appear to click in. I pushed all the way in on it with a screwdriver and it springs back. Is that normal? If not, do I have to replace the whole housing?
Never got it fixed. Order a plunger piece for it but that did work. So just use a credit card to open it.What did you do to repair the missing/broken part?
I’m in the same
I ordered a fuel door shell as dealer calls it. Basically replaces the door plastic shell and spring plunger missing piece. It comes tomorrow. I’ll let you know. Was $25.What did you do to repair the missing/broken part?
I’m in the same
