2006 Suburban 3" lift
boarder421
I'm getting axles with 4.10 gears and putting a trutrac in the rear. I want to put 285/75r17. I'm thinking to do a 3" Atomic coilover in front and skyjacker c25r and maybe a small spacer in the rear with matching viking shocks and longer sway bar links.
Would I benefit from nnbs cv axles, uca's or adjustable panhard bar? Anything I'm missing?
B
boarder421
Does anybody know the lift difference between Moog 81069 and skyjacker c25r?
dps01
Senior Member
Navy Supporting Member
N. TEXAS
Believe that the Moog 81069 is the Z71 rear spring. Not sure how it compares to the C25R.
B
boarder421
It looks like most people using the moog are using a spacer too.
I'm going to get the skyjackers and see how they match the 3" coilovers in the front.
dps01
Senior Member
N. TEXAS
For comparison:
2003 Z71 stock height in the rear, and leveled in the front using stock torsion bar keys; running BFG 285/75R17.
Replacement Moog 81069 springs with air bladders for a Ram 1500 inserted ready to be installed.
Rear height is 39” from ground to lower fender lip unloaded.
Front is 37” from ground to lower fender lip.
The Atomic Fab coil-overs is on the wishlist .
Trey Hardy
Panhard bar wouldn’t be a bad idea but not really needed unless your over 4” in the rear
With a 3” lift you would benifit with a good set of control arms to correct the ball joint angle
Cognito arms are good so are the kryptonite arms if you got the money find a set of uniball style uca it’ll give you more down travel and smoother ride paired with the new coil overs it’ll make a big difference
Some solid sway bar links like the cognito or kryptonite ones or if money allows it a set of hellwig sway bars will make a considerable difference In handling as well
I run all kryptonite ball joints and wheel bearings in my trucks and have had good luck with them so far
B
boarder421
I installed the axles and coilovers. I used the moog coils and 275 70 18 duratracs. The Atomic kit worked great, I put bilstien 5100 in the rear.
Fenders height is 39"
ZEUS1
For comparison:
Do you have any pics of that air bag set up. I want to do one so i can level out when towing.
B
boarder421
They are Air Lift air bags. The bladders go inside the coil springs and you run each line to a Schrader valve. I put my Schrader by the hitch. They work great for the price.
dps01
Senior Member
N. TEXAS
Set up on 2003 Z71.
Schrader valves installed on receiver hitch plate..
New Z71 springs with Ram Truck air bladders ready to install to replace existing (above).
Dh1280
