Most miles with stock AFM system?
Marky Dissod
My 2016 Tahoe just turned 165K miles. 100% stock no issues.
I know I should get it tuned but do not trust any shops here in Florida, NYC or NJ to tune out the AFM. Do not want to hook up the Range.
Still runs like brand new. Still using 0w20. Change out every 5K miles with either Mobil 1 EP or AC Delco.
@BlackBearPerf Now if they came anywhere near my neck of the woods or in NYC-N.J. I would let them tune it.
Look up
www.PCMperformance.com
Next time you're in Brooklyn or Queens ...
06 Yukon XL
Yep, good to know.
I was just curious as the whether any holdouts had accumulated as much miles as I have while still running the stock system.
I probably should have realized that it is highly unlikely that anyone still running the OEM system will ever see this thread. I'll be surprised if I get any responses at all, now that I think about it.
Oh, well.
I M at 262,000km with original engine, vehicle 5.3 Yukon XL, 2010
stimpster
I read a lot about deactivating the stock AFM system because of the many reports of trouble. But I often wonder who has accumulated the most trouble-free miles while running the OEM system. I have 114,000 on my '16 Tahoe, and no trouble yet (fingers still crossed).
166k then I had to replace the engine. 2008 5.3 LC9 flex
RobH
San Antonio
2016 Tahoe 5.3L. 135,000 miles. Stock AFM.
I have started driving with the transmission in M5. Plan to get a tune. Really don't want to have to get the engine repaired on a road trip. I can also get the transmission pressures adjusted to help my reman transmission live.
Does a person have to pull the heads to do an AFM delete and, if so, why?
Jeff_
Scottsdale, AZ & N. Idaho
Yes, gotta change lifters and many other parts to mechanically delete the AFM system.
I'm going to mechanically delete all the AFM components eventually. Just gotta pull the trigger on it which is like $8k including labor if I want a good performance shop here to do it.
RobH
San Antonio
I've changed lifters before without pulling the heads. Removed the rocker covers, removed the rocker arms, pulled the pushrods, and pulled the lifters. That was before roller hydraulic lifters and the LS/LT engines, though. Removed the cam out through the front of the engine compartment after removing the grille and AC condenser and radiator. Saves the back lifting out and returning the heads. Plus the head bolt removal/replacement/torquing and gaskets.
Perhaps the valley cover or something requires head removal.
Marky Dissod
Does a person have to pull the heads to do an Engine Half@$$ delete, and if so, why?
Could swear there's some sort of trick, where you spin the crank slowly, which lifts individual lifters as they ride different cam lobes,
and you can pull them out one or two at a time - but I've never done it myself so don't quote me, please.
the 18th letter
Northern New Jersey
My brothers 09 Tahoe just passed 205k with stock AFM running. I don’t think he owns a wrench but he does get it regularly maintained at a private garage. He bought it with a 100k on it.
2001 TX Tahoe
My 2016 Tahoe just turned 165K miles. 100% stock no issues. I know I should get it tuned but do not trust any shops here in Florida,NYC or New Jersey to tune out the AFM. Do not want to hook up the Range.
Curious why you don't want to use the Range?
topof81611
173k on 2016 5.3 stock tune and 10k oil change intervals with Mobil Delvac 1 ESP 0w40. I realize this is a pretty unconventional choice and I run it for a lot of miles but I will put cam and non dod lifters in at first signs of a problem. We have a very mixed fleet and this oil is in almost everything from large diesels to small air cooled engines for the past 7 years and no oil related failures to date. Roast away!!!
JamesinAbilene
