Help. Parking brake light stays on.
T-Bagg
The Esca-Hoe driver.
Doesn't Matter
So, I just changed my rear brake shoes. Now my parking brake light won't go out. I'm 99 percent sure the brakes are not engaged. Release doesn't do anything, pedal is up, and there is slack in the cable going back to the brakes.
While changing them I accidentally dropped the lever off the end of the cable and the only way I could get it back on was to disconnect the cable at that little union under the driver door.
I'm guessing it must just be the switch that turns on the light, but I don't know where that is. I would like the comfort of knowing 100% I'm not riding my brakes.
Any help would be appreciated.
T-Bagg
T-Bagg
Doesn't Matter
Update: Tried bleeding brakes. While doing found the left wheel cylinder leaking/sucking in air. Replaced, bleed and serviced(holy shit there was a lot of air in there.) Light out.
Thanks for you input fire730, it was much appreciated.
briannorris
