- Joined
- Aug 2, 2018
- Posts
- 6,578
- Reaction score
- 8,640
This is a first for me. Yikes!
You are right and especially these bolds never get loose when tight properly. There is not much vibration and due to the permanent heat change, water and dirt, they rather have the tendency to get rust tight, then to loosen themself. I would also speculate, they were never tightened properly, since last mount...Dang! Never heard or seen this.
Where the calipers ever removed at any point? I know the front calipers on my 99 Silverado specs are like 150 lb-ft or something like that. And the bolts have some sort of thread locker. Admittedly, I have only re tightened them spec but have never reinstalled any thread locker compound.
I've never removed the rears though. They are still the original at 270k miles. A long time ago my mechanic replaced an axle shaft that got bent when I got a curb on a patch of ice. I guess one rear caliper at least got removed and reinstalled...
the main thing here is that critical parts like braking need to have proper bolt torque, over/under causes things like this.The main tendence is bad maintenance...
even 20 year old factory loc tite still works well. them bolts take a lot to break free.
you'd almost think the bolts were cleaned off. even after 175,000 miles and new brakes every year on my 97 3500 pick up where you cant get the caliper pins out so you need to take the caliper with its bracket, every damn time it took way more force to get them broke free with the factory loctite still on there.And it seems like some blue loctite would have a good purpose here.
So that's enough evidence for an indictment. Who was the alleged perpetrator?
