Who using Arnott AS3066 and AS3429 rear shocks ?
Slow5.0
Missouri
Im about to order replacement front and rear shocka. I wanted to know if more of you guys using AS3066 than AS3429 rear shock. I know AS3066 is Eibach shock with Goodyear air bag and AS3429 is standard shock with Goodyear airbag. AS 3066 should be little bit stiffer than AS3429
So lets see who using what from these two rear shocks
Thanks
Big Mama
Virginia
I just replaced front and rear with Arnott but can’t recall the part number. I bought the rebuilt set since they have lifetime warranty. Initially I went with the passive setup to save some cash but that was a mistake.
Thanks
both are passive shocks
one is monotube (as3429)
one is twin tube (as3066)
unless you are getting rid of autoride I would not use either one.
if you are eliminating autoride then generally twintube should be better, that's why it cost's more.
Slow5.0
Slow5.0
Missouri
Magnaride shocks were all bad. All 4. Leaking bad. Installed Arnott SK3353 front and AS3066 rear shocks. This fixed bouncing problem. Also vibration on 70mph is also gone. Yukon ride just like it did in 2016 when i bought it new. No more stupid seized up magnaride shocks
Durobans
