Carlo
Left front wheel bearing is making humming sound. So I guess the wheel bearing is going....Is it necessary to change the whole hub or can I replace only the bearing? Thanks for your help.
The hub is a sealed unit. Buy a good one - Timken or OEM.Left front wheel bearing is making humming sound. So I guess the wheel bearing is going....Is it necessary to change the whole hub or can I replace only the bearing? Thanks for your help.
So you see, really a newbie....thanks for your help, appreciate it.
I like replacing the bearings you can get the preload correct that way , however there's very few places that will do it , An old time machine shop can do this And with 0 preload they will last forever. Otherwise you have to buy the whole assembly. Buy 1 with the guarantee, if you can find it. Try and find 1 with the copper crush Bearing preload inside, They should be a lot better because they have minimum preload.. GM screws up a lot of these bearings , Was sloppy Assembly All the corvettes from 63 up Had problems actually bearings, Were too tight , Or to o loose, and burned out . There is no provision for repacking. .Tapered roller bearings Cant have More than a fraction of an oz of preload, Nor can they have ,3 4, 1000s slop , The will wear out right away flake off, but Last much longer if you can get lube On them to keep them clean at least. A machine shop could do this there are some kits for some tapered roller bearings that were on the market For adding lubes.. on Tables I have removed the Brake sensors to enable Me to add Molly gear lube, inserted into the Front 4 wheel drive bearing units. So far this is worked perfectly. I'll let you guys know after a couple of hundred K.Left front wheel bearing is making humming sound. So I guess the wheel bearing is going....Is it necessary to change the whole hub or can I replace only the bearing? Thanks for your help.
miles. The unmasked mechanic big John
I don't believe that it has any effect at all on these hubs. It's a solid steel collar that goes all the way through that the hub nut tightens against. It doesn't compress the bearings on these rigs at all.The only preload I'm aware on new, sealed, bearings is the axle nut torque. If you run er home with the old impact, chances are you'll get to do it again in a few thousand miles. You can run the nut down with the impact, but do the last couple threads with a torque wrench and a long pry bar to lock the hub from turning. Or, put the wheel on and let it touch the ground with enough weight to prevent the tire from spinning (if you have a center cap that allows for access).
We had an 08 Tahoe and over its life we replaced front wheel bearings 3 times. They are famous for that.Left front wheel bearing is making humming sound. So I guess the wheel bearing is going....Is it necessary to change the whole hub or can I replace only the bearing? Thanks for your help.
