Escalade ESV
Definition
I don't know much about lowering trucks but I managed to lower mines with a ground force kit 2/3 with keys...
Well I want to lower it MORE, maybe 3/6? lowest I can go on 26's...
I let the keys down some and can get right under the fender in the front, but don't have a clue about the rear.
I want at least 2.5/3 inch more drop in the back.
Thanks..:Handshake:
Anthony
2004 Tahoe LT (MA)
Westen MA
3/5 is lowest people here usually do. Go for air ride and you can lay frame
BlackDenali
Roof Rack ****
Boca Raton, Florida
1st - :pics-stfu:
2nd - 4/5 is about a low as you can go without notching the frame and doing a lot of trial and error to find a shorter rear spring that ride halfway decent
D
Definition
Lowered 2/3 on 26's well the front it 3/3 right now I want MORE...
NORCAL SS
SUV SUSPENSION GURU
Thanks..:Handshake:
front djm 3 inch lower control arms
rear djm trailblazer spring
rear djm 5 inch kit
pull fuse for the autoride
will be dropped and ride great. I sell the trailblazer djm spring alone which only i can get due to my friend mike at djm. Hit me up if your interested.
89 chevy
1st - :pics-stfu:
Im at a lil' over 6in in the rear not counting the body drop, and I am not notched.....and im planning on going .5 to 1" lower without notching.:emotions122:
D
Definition
rear djm 5 inch kit
So how much for everything I need for the REAR to get the lowest possbile.. I got the front covered, I think..!
D
Definition
rear djm 5 inch kit
I want the kit.
One question though, will I have an engine or check ride light on? Where is this fuse located at? I'd like to pull it and see if I get any codes prior to purchase. My manual doesn't say anything about auto ride fuses. I "heard" it was the relay attached to the relay box under the hood so I pulled it and got an engine light so I put it back in.
Thanks once again.
NORCAL SS
SUV SUSPENSION GURU
BEFORE i do any of the kits here locally or sell here online i allways have the customer pull the fuse and drive around for a day. the autoride should be fuse 1
D
Definition
I really don't know what fuse it is, I'll look into it some more tomorrow, if I can get something figured out, I'll purchase this kit from you.
Thanks.
denalianyone
NYBlackLade08
New York
the fuse is labeled "RTD" (real time dampening).
---------- Post added at 07:01 PM ---------- Previous post was at 07:00 PM ----------
your escalade looks sexy by the way
AdrienR
