2006Tahoe2WD
okay, doesn't look that bad. I'm not at that point yet. Let's see if I can resolve the P0442 (small evap leak) without needing to replace the pressure sensor.
Summit has this block off plate. Is this what you were thinking of?Yea, that O2 was a return. What brand did you get? I would only use Genuine GM, Delphi or Denso. The block off plate leak will happen again if just use a gasket. Use a Billet plate and seal. Can get at Amazon.
This is the same one I used on my 2002 Tahoe LT. Worked great.
Okay, excellent thanks.This is the same one I used on my 2002 Tahoe LT. Worked great,
If you are going to replace the OEM block off plate this ICT one, I want to purchase the OEM plate. I will send a USPS money order plus shipping . PM me with your mailing address.
Sure. Did you try one of the AL plates and it didn't work or do you need the OEM plate for some other reason? You don't have to mention the reason I'm curious because if I send you the OEM plate and then need it back etc etc.If you are going to replace the OEM block off plate this ICT one, I want to purchase the OEM plate. I will send a USPS money order plus shipping . PM me with your mailing address.
